# Build and run an Android chat app
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/)
- [Create a development environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/1-dev-env-setup/)
- [Build ONNX Runtime](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/2-build-onnxruntime/)
- [Build ONNX Runtime Generate() API](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/3-build-onnxruntime-generate-api/)
- [Run a benchmark on an Android phone](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/4-run-benchmark-on-android/)
- [Build and run an Android chat app](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/5-build-android-chat-app/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/_next-steps/)
Another way to run the model is to use an Android GUI app. You can use the Android demo application included in the [onnxruntime-inference-examples repository](https://github.com/microsoft/onnxruntime-inference-examples) to demonstrate local inference.
## Clone the repo
```bash
git clone https://github.com/microsoft/onnxruntime-inference-examples
cd onnxruntime-inference-examples
git checkout 7a635daae48450ff142e5c0848a564b245f04112
> You could probably use a later commit but these steps have been tested with the commit `7a635daae48450ff142e5c0848a564b245f04112`.
## Build the app using Android Studio
Open the `mobile/examples/phi-3/android` directory with Android Studio.
### (Optional) In case you want to use the ONNX Runtime AAR you built
Copy ONNX Runtime AAR and ONNX Runtime GenAI AAR you built earlier in this learning path:
```bash
Copy onnxruntime\build\Windows\Release\java\build\android\outputs\aar\onnxruntime-release.aar onnxruntime-inference-examples\mobile\examples\phi-3\android\app\libs
Copy onnxruntime-genai\build\Android\Release\src\java\build\android\outputs\aar\onnxruntime-genai-release.aar onnxruntime-inference-examples\mobile\examples\phi-3\android\app\libs
Update `build.gradle.kts (:app)` as below:
```kotlin
// ONNX Runtime with GenAI
//implementation("com.microsoft.onnxruntime:onnxruntime-android:latest.release")
implementation(files("libs/onnxruntime-release.aar"))
//implementation(files("libs/onnxruntime-genai-android-0.8.1.aar"))
implementation(files("libs/onnxruntime-genai-release.aar"))
Finally, click **File > Sync Project with Gradle**.
### Build and run the app
When you select **Run**, the build will be executed, and then the app will be copied and installed on the Android device. This app will automatically download the Phi-3-mini model during the first run. After the download, you can input the prompt in the text box and execute it to run the model.
You should now see a running app on your phone, which looks like this:
![App screenshot](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-chat-app-using-onnxruntime/screenshot.png)
