Explore related resources
Give feedback
AI-assisted
Close
What do I need to check before applying these optimizations?
Enable hardware ray tracing for Lumen on the target Android device as referenced in the prerequisite guidance. Open the Unreal Engine project and the level you plan to optimize.
How do I exclude nonessential actors from ray tracing?
Use the actor details panel and turn off ray tracing visibility for objects that do not affect lighting or are very small. Preview the scene to confirm that lighting quality remains acceptable.
How can I confirm whether repeated objects are instanced?
Run the command r.RayTracing.Debug.PickerDomain 1 to set the picker to instance mode, then use Ray Tracing Debug and select Picker. Click scene elements to inspect their instancing status and convert repeated objects to instanced actors when possible.
What should I look for in the Instance Overlap view?
Open the Instance Overlap view under Ray Tracing Debug and look for areas showing high overlap. Adjust meshes and actor bounds so each bounding box contains minimal empty space and overlaps less with neighbors.
Why does removing small or overlapping geometry help?
You reduce hit tests because the acceleration structure stores scene geometry in a hierarchy. Fewer, less-overlapping bounds lower traversal work, which can improve hardware ray tracing efficiency.
Return to Mobile, Graphics, and Gaming
