The next optimization is around instanced actors. Instanced actors can share the same geometry data in the BLAS of the acceleration structure, thereby saving memory usage and increasing cache hits. To achieve the best performance and memory efficiency when using hardware ray tracing, you should use object instancing as much as possible.
Here are the steps for checking the instancing status in Unreal Editor:
  1. Use command r.RayTracing.Debug.PickerDomain 1 to select the instance mode for picker:
Image Alt Text:Unreal Editor command field containing r.RayTracing.Debug.PickerDomain 1, which sets the ray tracing picker to instance mode.
  1. In the Unreal editor, under Ray Tracing Debug, select Picker:
Image Alt Text:Unreal Editor Ray Tracing Debug menu with Picker selected, ready to inspect an instance in the scene.
  1. Use the mouse cursor to select the instance you want to check. The acceleration structure information for this instance will be displayed on the screen. Use the detailed information under [BLAS] to verify if two instances share the same BLAS data:
Image Alt Text:Unreal Editor Ray Tracing Debug view with a selected scene object and an on-screen information panel listing its instance ID and BLAS name. Compare the BLAS name for two objects to check whether they share geometry data.
