# Acceleration Structure
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/)
- [Lumen and Ray Tracing](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/1-ray-tracing/)
- [Acceleration Structure](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/2-acceleration-structure/)
- [Only Add Important Objects into Ray Tracing](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/4-add-object/)
- [Take Full Advantage of Instancing](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/5-instancing/)
- [Optimize Acceleration Structure](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/6-optimize-as/)
- [Reduce Acceleration Structure Run-time Update Cost](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/7-run-time-update/)
- [Lumen General Setting Optimizations](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/8-lumen-general/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/_next-steps/)
## What is an Acceleration Structure?
An acceleration structure is a data structure designed to improve ray traversal speed on ray tracing hardware. It uses a hierarchical tree to store the geometry data of the scene, minimizing the number of hit tests between rays and geometry. Ray tracing hardware typically utilizes this structure to quickly identify the triangles that intersect with a ray.
As shown in the image below, the scene is divided into boxes, and the acceleration structure stores the hierarchical tree of all these smaller boxes. During ray traversal, the hardware can use this structure to quickly locate the boxes that intersect with a ray. Subsequently, the hardware can then find the intersections between the ray and the triangles within those volumes.
![Image Alt Text:Diagram of a scene divided into nested bounding boxes, with a ray passing through the boxes toward the geometry. The hierarchy lets ray tracing test relevant regions instead of every shape.](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/images/as2.png)
*Figure1. The acceleration structure used to represent a scene.*
In a typical game scene, there are often many duplicated objects that share the same geometry data but have different instance attributes, such as position or color. Therefore, the acceleration structure is divided into two levels: the Top Level Acceleration Structure (TLAS) and the Bottom Level Acceleration Structure (BLAS), as shown below.
![Image Alt Text:Acceleration-structure tree with a TLAS above four instances, three BLAS nodes, and geometry beneath them. Two instances reference the same BLAS, showing how duplicated objects share geometry data.](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/best-practices-for-hwrt-lumen-performance/images/as.png)
*Figure2. The acceleration structure tree.*
### TLAS
The TLAS only stores the instancing data of the BLAS, such as the transform data of each instance. It does not store any geometry data. Instead, it references the relevant BLAS. This approach allows the hardware to save memory by storing a single set of geometry data for many duplicated objects.
### BLAS
The BLAS stores the geometry data and hierarchical bounding boxes of the scene. Multiple instances in the TLAS can point to a single BLAS.
