Once a Render Pipeline is created, you can use WebGPU APIs to create and render a 3D mesh. This is similar to other graphics APIs.
The steps are listed below:
All these steps are common in graphics programming, and WebGPU allows you to perform these same operations.
It is a good idea to read the individual chapters in the 3D Rendering section to learn more.
In this Learning Path you can use OBJ files to define 3D meshes.
Instead of manually parsing OBJ files, you can use the TinyOBJLoader library.
The file format is not complex, but parsing files is out of the scope of this Learning Path.
You can use open-source software such as Blender to create your own 3D objects.
Only one of your source files must define TINYOBJLOADER_IMPLEMENTATION before including it:
#define TINYOBJLOADER_IMPLEMENTATION // add this to exactly 1 of your C++ files
#include "tiny_obj_loader.h"
There is a helper function
loadGeometryFromObj
available to load objects.
You are now ready to render a 3D object.
You can run a rendering pass and draw something onto our surface.
To encode any commands to be issued to GPU, you need to create a CommandEncoder. Modern APIs record commands into command buffers, rather than issuing commands one by one, and submit all of them at once.
In WebGPU, this is done through a CommandEncoder as shown below:
wgpu::CommandEncoderDescriptor commandEncoderDesc;
commandEncoderDesc.label = "Command Encoder";
wgpu::CommandEncoder encoder = device.createCommandEncoder(commandEncoderDesc);
The next step is to create a RenderPassEncoder.
It encodes commands related to controlling the vertex and fragment shader stages, as issued by RenderPipeline.
It forms part of the overall encoding activity of a CommandEncoder. A render pipeline renders graphics to Texture attachments, typically intended for displaying on a surface, but it could also render to textures used for other purposes that never appear onscreen.
It has two main stages:
You can create a RenderPassEncoder using the encoder.beginRenderPass() API:
wgpu::RenderPassDescriptor renderPassDesc{};
wgpu::RenderPassColorAttachment renderPassColorAttachment{};
renderPassColorAttachment.view = nextTexture;
renderPassColorAttachment.resolveTarget = nullptr;
renderPassColorAttachment.loadOp = wgpu::LoadOp::Clear;
renderPassColorAttachment.storeOp = wgpu::StoreOp::Store;
renderPassColorAttachment.clearValue = Color{ 1, 1, 1, 1.0 };
renderPassColorAttachment.depthSlice = WGPU_DEPTH_SLICE_UNDEFINED;
renderPassDesc.colorAttachmentCount = 1;
renderPassDesc.colorAttachments = &renderPassColorAttachment;
renderPassDesc.timestampWrites = nullptr;
wgpu::RenderPassEncoder renderPass = encoder.beginRenderPass(renderPassDesc);
ColorAttachment is the only mandatory field. Make sure you have specified renderPassColorAttachment.depthSlice.
It is recommended to go through the ColorAttachment members .
You can invoke the following APIs to draw 3D object:
renderPass.setPipeline(...);renderPass.setVertexBuffer(...)renderPass.setBindGroup(...)renderPass.draw(...)To finish encoding the sequence of commands and issue them to the GPU, a few more API calls are needed:
End render pass renderPass.end()
Finish the command
wgpu::CommandBufferDescriptor cmdBufferDescriptor{};
cmdBufferDescriptor.label = "Command buffer";
wgpu::CommandBuffer command = encoder.finish(cmdBufferDescriptor);
encoder.release();
Submit the Queue queue.submit(command)
Present the object onto surface surface_.present()
Make sure you release the created encoders and buffers by calling the respective .release() in order to avoid dangling pointers or other errors.
By default, Dawn runs callbacks only when the device “ticks”, so the error callbacks are invoked in a different call stack than where the error occurred, making the breakpoint less informative.
To force Dawn to invoke error callbacks as soon as there is an error, you can enable an instance toggle:
#ifdef WEBGPU_BACKEND_DAWN
// Make sure the uncaptured error callback is called as soon as an error
// occurs rather than at the next call to "wgpuDeviceTick".
WGPUDawnTogglesDescriptor toggles;
toggles.chain.next = nullptr;
toggles.chain.sType = WGPUSType_DawnTogglesDescriptor;
toggles.disabledToggleCount = 0;
toggles.enabledToggleCount = 1;
const char* toggleName = "enable_immediate_error_handling";
toggles.enabledToggles = &toggleName;
desc.nextInChain = &toggles.chain;
#endif // WEBGPU_BACKEND_DAWN
Toggles are Dawn’s way of enabling/disabling features at the scale of the whole WebGPU instance.
See the complete list in Toggle.cpp .
You are now ready to build and run the application.
First, copy the files with the shader code and 3D object files to a connected phone:
cd ~/AndroidStudioProjects/dawnwebgpu/app/src/main/cpp
adb shell "mkdir /data/local/tmp/webgpu/"
adb push resources/shader_texture_file.wgsl /data/local/tmp/webgpu/
adb push resources/cone_in_turdis.obj /data/local/tmp/webgpu/
adb push resources/cone_in_turdis.mtl /data/local/tmp/webgpu/
If adb is not in your search path, enter the path to adb.
For example:
~/Library/Android/sdk/platform-tools/adb shell "mkdir /data/local/tmp/webgpu/"
Now click the Run icon in Android Studio, which builds the application and launches it on the connected device, producing the following output:
Figure 10: Output
Congratulations! You have now run a WebGPU application on an Android device.
