Graphic applications must operate with two processors, the CPU and the GPU.
These two processors run on different timelines. For optimal performance, commands intended for the GPU are batched and sent through a command queue. The GPU consumes this queue whenever it is ready, and in this way, processors minimize the time spent idling for their sibling to respond.
A WebGPU device has a single queue, which is used to send both commands and data. You can get it with wgpuDeviceGetQueue().
WebGPU offers three different ways to submit work to this queue:
Other graphics API allow you to build multiple queues per device.
If you would like to learn more, refer to the Command Queue .
WebGPU is a simple system. It runs three types of functions on the GPU:
Here is a simplified diagram of a WebGPU setup to draw triangles by using a vertex shader and a fragment shader:
Figure 8: Triangle using WebGPU
The main things to notice in the above image are:
To execute shaders on the GPU, you need to create all of these resources and set up this state. Creation of resources is relatively straightforward.
Most WebGPU resources cannot be changed after creation. You can change their contents but not their size, usage, and format.
If you want to change something create a new resource and destroy the old one.
In order to achieve high performance real-time 3D rendering, the GPU processes shapes through a predefined pipeline. The pipeline itself is always the same, but you can configure it in many ways.
To do so, WebGPU provides a Render Pipeline object. The figure below illustrates the sequence of data processing stages executed by the render pipeline.
Figure 9: Render Pipeline
The Render Pipeline has two main types of stages, fixed-function and programmable.
The pipeline description consists of the following steps:
The fixed function stages are well-documented, and you can refer to code and further reading for information about configuring them.
Configuring these stages is straightforward and is similar to other graphics APIs.
There are two programmable stages, vertex, and fragment programmable stages. Both of them use the Shader Module.
Both the vertex and fragment programmable stages can use the same shader module or have individual shader modules.
The Shader module is like a dynamic library (such as a .dll, .so, or a .dylib file), except that it uses the binary language of your GPU rather than that of your CPU.
The shader language officially used by WebGPU is called WebGPU Shading Language, WGSL .
All implementations of WebGPU support it, and Dawn also offers the opportunity to provide shaders written in SPIR-V .
WGSL was originally designed to be a human-editable version of the SPIR-V programming model, so transpilation from SPIR-V to WGSL is in theory efficient and lossless. You can use Naga or Tint to translate.
It is recommended that you learn about the WGSL syntax and capabilities to better program in WebGPU.
It is simple to create a Shader module in WebGPU. Use the following code:
ShaderModuleDescriptor shaderDesc;
ShaderModule shaderModule = device.createShaderModule(shaderDesc);
By default the nextInChain member of ShaderModuleDescriptor is a nullptr.
The nextInChain pointer is the entry point of WebGPU’s extension mechanism. It is either null or pointing to a structure of type WGPUChainedStruct.
It may recursively have a next element (again, either null or pointing to a WGPUChainedStruct).
Secondly, it has the struct type sType, which is an enum reporting in which struct the chain element can be cast.
To create a shader module from WGSL code, use the ShaderModuleWGSLDescriptor SType.
In Dawn, a SPIR-V shader can similarly be created using the WGPUShaderModuleSPIRVDescriptor.
The field shaderCodeDesc.chain corresponds to the chained struct when cast as a simple WGPUChainedStruct, that must be set to the corresponding SType enum value:
ShaderModuleWGSLDescriptor shaderCodeDesc;
// Set the chained struct's header
shaderCodeDesc.chain.next = nullptr;
shaderCodeDesc.chain.sType = SType::ShaderModuleWGSLDescriptor;
// Connect the chain
shaderDesc.nextInChain = &shaderCodeDesc.chain;
shaderCodeDesc.code = shaderSource;
In this project, a helper function
loadShaderModule
reads the shader code from a file and creates a shader module for the device.
The shaders might need to access input and output resources such as buffers and textures.
These resources are made available to the pipeline by configuring a memory layout.
Now you can finally create a render pipeline by calling the createRenderPipeline() :
wgpu::RenderPipelineDescriptor pipelineDesc;
//Configure fixed and programable stages
wgpu::RenderPipeline pipeline = device.createRenderPipeline(pipelineDesc);
Continue to the next section to learn more about rendering a 3D object.
