Explore related resources
Give feedback
AI-assisted
Close
What result should I expect when I run the app after adding OpenCV?
You should see a camera preview from JavaCameraView after granting camera permission. Starting the preview shows live frames. To switch to an adaptive thresholded image, check the processing checkbox.
Where do I add the camera view and UI controls?
Edit activity_main.xml to include a JavaCameraView, start and stop buttons, and a checkbox. Replace the existing layout with the provided XML so the controls appear correctly.
Which OpenCV component provides frames for processing in this app?
JavaCameraView supplies camera frames. You’ll process those frames as OpenCV Mat objects in your activity code.
Do I need to use the exact project and package names shown?
Using the provided names is recommended. However, you can choose different names, as long as you stay consistent across the project configuration and code.
What should I check if the camera preview doesn't appear?
Verify the app has camera permission and that the JavaCameraView is present in the layout. Use the start control to begin the preview before expecting frames to update.
Return to Mobile, Graphics, and Gaming
