Analyze a frame from an Android application with Frame Advisor
Understand Frame Advisor and get support
Capture a trace in Frame Advisor
Analyze draw calls in Frame Advisor
Analyze frame construction with the Render Graph in Frame Advisor
Analyze mesh geometry with Content Metrics on Frame Advisor
Open New Trace and check that your device and the target application appear in the lists.
Select Vulkan for Vulkan applications and OpenGL ES for OpenGL ES applications. Set this under API settings before starting the capture session.
After you start the session, you can play to the problem area while the application launches automatically on the device and captures. When analysis completes, you’ll see the Frame hierarchy with frames, render passes, and draw calls.
In the Render Graph, follow the flow from left to right and look for the pass that outputs to the swapchain. That pass is the final stage that renders to the screen.
Open Content Metrics, choose Draws, and sort by the highest number of primitives to surface complex objects. Right-click a candidate and select Navigate to call to highlight it in the Frame hierarchy and view it in the framebuffer.
