Give feedback
AI-assisted
Close
How do I confirm that my Android phone is connected and authorized for debugging?
Run adb devices -l and confirm that your phone appears as an authorized device. If you see unauthorized, unlock your phone, accept the USB debugging prompt, and run the command again. If your phone doesn’t appear, see Run apps on a hardware device .
Which model ZIP should I use with Vision Chat?
Use the supported Qwen3-VL 2B Instruct package from the Arm AI Portal. You’ll get one GGUF file for the language model and one for the vision projector, both targeting llama.cpp. When you import the ZIP, Vision Chat validates both files before extracting them.
What do I need to provide to run a vision-language inference?
Provide one image and a text prompt. After you import the model package, select Choose a photo and choose an image. Enter your prompt, then select Ask Qwen3-VL to generate text locally on your phone.
What result should I expect after running Vision Chat?
You’ll receive generated text based on your selected image and prompt. You’ll also see the model-load time, image-and-prompt evaluation time, output-token count, and decode speed measured on your phone.
Why does the model package contain two GGUF files?
The ZIP file that you import contains two GGUF files because llama.cpp separates the language model from the vision encoder and projector. When you run inference, Vision Chat loads the Q4_K_M language-model GGUF and the matching Q8_0 mmproj GGUF together.
Return to Mobile, Graphics, and Gaming
