Explore related resources
Give feedback
AI-assisted
Close
How do I verify that my Android phone is connected to adb?
Run adb devices -l. Confirm that your phone appears with a device serial and the state device. If it reports unauthorized, unlock the phone and accept the debugging prompt.
What should I check if adb doesn't list my phone on Linux?
Ensure Android udev rules are installed and that your user belongs to the plugdev group. Reconnect the device after updating the rules or group membership.
How does the confidence threshold affect object detection?
A higher confidence threshold removes more lower-scoring detections. Reduce the model’s default threshold if it doesn’t display expected objects, but be aware that lower thresholds can increase false positives and the amount of work passed to non-maximum suppression.
How do I add a detector that Scene Detector doesn't support?
Register the model directly if it matches a supplied detector strategy. Otherwise, use the coding agent workflow to generate another adapter.
How do I run detection on a saved image?
Import a supported .pte or .tflite model, select Choose saved image, choose an image, and select Detect objects. The application displays the annotated image, detected objects, confidence scores, and processing time.
Return to Mobile, Graphics, and Gaming
