Choose an implementation route
Scene Detector already supports the YOLO models listed in the supported model table on Import and run an Arm AI Portal object-detection model . You don’t need to change the application to use those models.
You can try one of two hands-on routes to use a model that Scene Detector doesn’t currently support:
  • Register the model directly when it matches a supplied detector strategy
  • Use the coding-agent workflow to generate another adapter.
Record the following information for the model and compare them with the supplied strategies before changing code:
  • Runtime
  • Callable method
  • Input shape
  • Layout
  • Data type
  • Resize method
  • Normalization
  • Output tensors
  • Label set
  • Box format
  • Postprocessing requirements
Model compatibilityHands-on workflow
Matches a supplied strategy’s methods, tensors, preprocessing, labels, box format, and postprocessingRegister another compatible model
Differs in any of those areasGenerate another adapter using a coding agent
Sharing a runtime doesn’t make detector packages interchangeable. ExecuTorch or LiteRT detector packages can expose different tensors, box formats, preprocessing, and output decoding.
You can reuse a supplied strategy when another model has the same complete execution contract as one of the supported packages.
Download the model using its repository ID:
printf 'Arm model repository ID: '
read -r MODEL_ID
export MODEL_ID
export MODEL_FILE="$(.hf-venv/bin/python download_model.py \
  --repo-id "$MODEL_ID" \
  --print-path)"
$MODEL_ID = Read-Host "Arm model repository ID"
$MODEL_FILE = .\.hf-venv\Scripts\python.exe download_model.py `
  --repo-id "$MODEL_ID" `
  --print-path
If the repository contains more than one .pte or .tflite file, rerun the downloader with --filename followed by the exact model filename.
Add one descriptor to the list returned by CompatibleModelRegistry.models(). This example registers another detector that matches the supplied YOLOv8 strategy:
static List<ModelDescriptor> models() {
    return List.of(
            new ModelDescriptor(
                    "my-yolov8-detector",
                    "My YOLOv8 detector",
                    ExecuTorchObjectDetectionAdapter.ID,
                    "ExecuTorch",
                    "my-yolov8-detector.pte",
                    ExecuTorchObjectDetectionAdapter.CONFIG_YOLO_V8,
                    75
The filename must match the downloaded file. Select the configuration that matches the complete model package, then rebuild and install the APK. Importing the model automatically activates the supplied ExecuTorch adapter and its confidence control.
Don’t register a detector based only on its .pte extension or family name. A different export can change tensor ordering, box encoding, label mapping, or postprocessing while keeping a similar repository name.
Determine when the supplied adapter doesn’t fit
Add a strategy inside the matching supplied adapter when the model keeps the same single-image or camera workflow and runtime but needs different preprocessing or output decoding.
The strategy must validate the model methods or tensor shapes and prepare the input expected by the package. It must also decode boxes and class scores, scale coordinates back to the source image, and apply the documented confidence filtering and non-maximum suppression. Add a configuration constant to the matching adapter and reference it from the model descriptor.
Use the model package as the source of truth. A detector can load and execute while producing misplaced boxes or incorrect labels because any of the following are wrong:
  • Resize
  • Padding
  • Coordinate system
  • Class mapping
  • Box decoder
Use a separate adapter when the runtime or callable methods change but the model still performs independent object detection on one bitmap at a time. The adapter can reuse the supplied confidence control and return bounding boxes through DetectionResult.
The supplied LiteRT adapter supports the registered YOLO11 and YOLO26 contracts. Add another LiteRT profile only when a model matches the same per-image workflow and DetectionResult output but needs different tensor handling or decoding. Use a separate adapter when the runtime or callable interface changes.
A separate adapter isn’t enough when the workflow no longer fits those shared interfaces. Tracking needs persistent state across frames. A multi-frame model needs frame scheduling and model inputs that preserve temporal order. Instance segmentation, pose estimation, or another task can need different result types, controls, and overlays. Extend DetectionAdapter.java, DetectionRunner.java, and MainActivity.java before adding such a workflow.
Keep image acquisition, model execution, and overlay rendering separate where possible. The supplied camera and document-picker paths both produce bitmaps, so another per-image detector can normally reuse them.
Use this workflow when the model doesn’t match every part of a supplied detector strategy’s contract. A coding agent can inspect the model package and prepare a build-time adapter for its preprocessing, task, runtime, and model format.
Note
Use an advanced coding agent that supports long-context, multi-file editing and terminal tools. The agent needs to be able to trace Java interfaces and reason about tensor, preprocessing, and box-decoding contracts. It needs to be able to update Gradle configuration and interpret build errors.
Treat generated code as a starting point that needs developer review and device validation.
Run the platform-specific project and Android SDK checks from the cloned project directory:
if [ ! -f "settings.gradle.kts" ] || [ ! -x "gradlew" ]; then
    printf 'Run this command from the cloned project directory.\n' >&2
    exit 1
fi
if [ -z "${ANDROID_HOME:-}" ] || \
   [ ! -d "$ANDROID_HOME/platforms/android-35" ] || \
   [ ! -d "$ANDROID_HOME/build-tools/35.0.0" ]; then
    printf 'Android SDK Platform 35 or Build-Tools 35.0.0 is unavailable.\n' >&2
    exit 1
fi
if (-not (Test-Path "settings.gradle.kts") -or
    -not (Test-Path "gradlew.bat")) {
    throw "Run this command from the cloned project directory."
if (-not $env:ANDROID_HOME -or
    -not (Test-Path "$env:ANDROID_HOME\platforms\android-35") -or
    -not (Test-Path "$env:ANDROID_HOME\build-tools\35.0.0")) {
    throw "Android SDK Platform 35 or Build-Tools 35.0.0 is unavailable."
Verify the project root, Java, and connected phone:
git rev-parse --show-toplevel
java -version
adb get-state
Check the huggingface_hub package with the Python executable for your operating system:
.hf-venv/bin/python -c \
    'import huggingface_hub; print(huggingface_hub.__version__)'
.\.hf-venv\Scripts\python.exe -c `
    "import huggingface_hub; print(huggingface_hub.__version__)"
The output includes the project root, Java version, device, and the installed huggingface_hub version. Resolve any error before continuing.
Also make sure:
  • Your coding agent is installed, authenticated if needed, and allowed to read, edit, and run commands in the project workspace
  • You have access to the model repository
  • You have access to an approved account and access token if you’re using a gated or private repository
  • You know the model runtime, tensor contract, preprocessing, box decoding, label mapping, and postprocessing from authoritative model documentation
  • You have enough disk space for the complete model package and representative images with known reference detections
Generated code might need review and iteration. Results depend on whether the coding agent can inspect files, edit multiple files, and run Android build commands.
Compatibility depends on the following factors:
  • Model package
  • Android runtime library
  • Native operators
  • Device ABI
  • Preprocessing information
  • Available backend support
Set the repository ID and runtime specified by the model package:
read -r MODEL_ID
printf 'Model runtime: '
read -r MODEL_RUNTIME
export MODEL_ID MODEL_RUNTIME
export MODEL_FILE="$(.hf-venv/bin/python adapter-generation/download_model_package.py \
  --print-model-path)"
export MODEL_DIR="$(dirname "$MODEL_FILE")"
$MODEL_RUNTIME = Read-Host "Model runtime"
$MODEL_FILE = .\.hf-venv\Scripts\python.exe adapter-generation/download_model_package.py `
  --print-model-path
$MODEL_DIR = Split-Path -Parent "$MODEL_FILE"
The download script retrieves the complete repository because the coding agent might need configuration, labels, anchors, or other package assets in addition to the primary model file.
If the package metadata references a missing file and the repository contains more than one optimized model, add --filename "<model-file>" to the download command.
The command stores the primary model binary in MODEL_FILE and the package directory in MODEL_DIR.
Inspect the package and create model-summary.json:
.hf-venv/bin/python adapter-generation/inspect_model_package.py \
  --model-dir "$MODEL_DIR" \
  --model-id "$MODEL_ID" \
  --runtime "$MODEL_RUNTIME"
.\.hf-venv\Scripts\python.exe adapter-generation/inspect_model_package.py `
  --model-dir "$MODEL_DIR" `
  --model-id "$MODEL_ID" `
Give your coding agent the following files from the project:
  • model-summary.json
  • adapter-generation/generate_mobile_adapter_prompt.txt
  • DetectionAdapter.java, AdapterDefinition.java, DetectionRunner.java, Detection.java, and DetectionResult.java
  • ModelDescriptor.java, GeneratedAdapterRegistry.java, and app/generated-runtime-dependencies.gradle.kts
  • ExecuTorchObjectDetectionAdapter.java
  • ExecuTorchYoloDetector.java, ExecuTorchDetrDetector.java, and ExecuTorchSsdDetector.java as strategy examples
The prompt tells the coding agent to keep the supplied ExecuTorch adapter unchanged. It can create a detector strategy or a runtime-specific adapter and register the adapter and model in GeneratedAdapterRegistry.java. It can also add reviewed resources and a required runtime dependency to app/generated-runtime-dependencies.gradle.kts.
The agent should report that the application contracts need to be extended when the package needs the following:
  • Tracking
  • Multi-frame input
  • Different controls
  • Multiple model files selected at run time
  • Another result type
The agent shouldn’t force the model into the supplied interface.
Review the generated source. The coding agent should run the included file check and report the exact command using the files it created. To run the check yourself, replace YourGeneratedAdapter.java with the generated class name:
.hf-venv/bin/python adapter-generation/validate_generated_adapter.py \
  --adapter "app/src/main/java/org/arm/learningpath/objectdetection/YourGeneratedAdapter.java"
.\.hf-venv\Scripts\python.exe adapter-generation/validate_generated_adapter.py `
Rebuild the application after reviewing the generated files:
./gradlew :app:assembleDebug :app:lintDebug
.\gradlew.bat :app:assembleDebug :app:lintDebug
Install the application and copy the model with the commands used on every operating system:
adb install -r app/build/outputs/apk/debug/app-debug.apk
adb push "$MODEL_FILE" /sdcard/Download/
Open the mode added by the generated adapter, import the copied model file, and follow its controls. A successful build confirms that the source compiles. However, it doesn’t prove that preprocessing, tensor values, labels, box decoding, or coordinate scaling are correct. Test images similar to what the application will receive on the target device, and compare the results with a known reference for the model package.
What you’ve accomplished
You’ve learned how you can extend Scene Detector to use an object-detection model that’s not currently supported.
You can now register a compatible detector with a supplied strategy or generate, build, and validate another adapter for a model with a different contract.
