How Scene Detector works
MainActivity.java connects the Android document pickers, saved-image and camera inputs, current model, confidence control, and result views. It discovers available detection modes through AdapterRegistry.java and moves model execution off the main Android user-interface thread so the screen remains responsive while a detector runs.
An adapter is the application-side integration layer between the shared Android screen and one model workflow. ExecuTorchObjectDetectionAdapter.java provides ExecuTorch detection, and LiteRtObjectDetectionAdapter.java provides LiteRT detection.
Models share an adapter when they use the same runtime, import flow, confidence control, and per-frame object-detection interface. They use different profiles when preprocessing, input precision, output tensors, score calculations, or postprocessing differ. Each adapter selects a profile from the imported model’s descriptor.
MainActivity.java supplies one bitmap at a time and displays the returned detections. Runtime-specific tensor and decoding code remains inside the adapter and detector.
How Scene Detector resolves and validates the model
ModelRegistry.java records the exact filename, model name, and runtime label for each package. It also records adapter ID, detector configuration, and default confidence threshold. ModelImporter.java rejects unregistered filenames and files larger than 700 MB. The downloader assigns unique import names when a package publishes a generic filename, such as model.pte.
The importer copies the file to temporary application-private storage. It then asks the adapter named by the descriptor to create and close a runner before the file replaces the installed model.
This validation checks the following:
  • The packaged runtime can open the model
  • The registered detector strategy is available
  • The ExecuTorch model provides a forward method and declares the XNNPACK backend
  • The LiteRT model exposes the registered input and output tensor types and shapes
Output tensor shapes and data types are checked during the first detection run because they aren’t available until the model executes. This is a compatibility check rather than an accuracy test or proof that the filename describes the file contents. A model can still produce poor results if its preprocessing, labels, box decoder, or postprocessing doesn’t match the registered strategy.
The adapters aren’t model executables. Gradle adds the ExecuTorch and LiteRT Android libraries when it builds the application, and their prebuilt arm64-v8a native runtime libraries are packaged in the Android application package (APK). The imported .pte or .tflite file contains the model program and parameters rather than new Android or Java code.
Keeping the model outside the APK lets you replace it without recompiling the application. Clearing the application data or uninstalling the application removes the imported copy.
How Scene Detector supplies pixels from an image or camera
MainActivity.java sends an Android bitmap to the selected detector regardless of where the pixels came from:
  • For the live camera, CameraX ImageAnalysis keeps only the latest frame while the previous frame is being processed.
  • For a saved image, Android’s document picker supplies one bitmap for an explicit detection run.
The camera and saved-image inputs use the same detector because both produce one bitmap per inference call. Temporal tracking or a model that consumes several frames together would require a different interface.
How Scene Detector routes the model to a YOLO profile
The selected adapter receives the registered model descriptor and creates the matching detector profile. ExecuTorchObjectDetectionAdapter.java creates an ExecuTorch detector, while LiteRtObjectDetectionAdapter.java creates a LiteRT detector.
The detector profiles isolate the parts that differ:
StrategySupplied modelsMain responsibility
ExecuTorchYoloDetector.javaYOLOv5s, YOLOv8s, and YOLOv9sSelect the matching YOLO input and output profile
ExecuTorchYoloxDetector.javaYOLOX-SPrepare BGR input and decode separate prediction heads
LiteRtYoloDetector.javaYOLO11n and YOLO26nSelect input precision, XNNPACK flags, and output decoding
How Scene Detector prepares and decodes YOLO models
ExecuTorchYoloDetector.java, ExecuTorchYoloxDetector.java, and LiteRtYoloDetector.java implement the registered detector profiles. The ExecuTorch models accept float32 tensors with shape [1, 3, 640, 640]. Their channel order, pixel range, image preparation, and outputs depend on the profile.
The following table compares image preparation, output, score calculation, and non-maximum suppression (NMS) intersection-over-union (IoU) between the profiles:
ProfileImage preparationOutputScore calculationNMS IoU
YOLOv5Resize directly to 640 × 640, values in [0, 1][1, 25200, 85]Objectness × best class score0.45
YOLOv8Resize directly to 640 × 640, values in [0, 1][1, 84, N]Best class score0.45
YOLOv9Letterbox to 640 × 640, padding with 114/255[1, 84, 8400]Every class score above the threshold0.70
YOLOX-SLetterbox to 640 × 640, top-left anchored, BGR values in [0, 255], padding with 114Nine tensors: box [1, 4, H, W], objectness [1, 1, H, W], and class [1, 80, H, W] at H = W = 80, 40, 20Sigmoid objectness × sigmoid best class logit0.65
YOLO26Letterbox to 640 × 640, padding with 114/255[1, 300, 6]Confidence supplied in each detection row0.40
YOLO11Letterbox to 640 × 640, padding with 114/255, then quantize to INT8[1, 84, 8400]Every class score above the threshold0.70
Direct resizing changes the image aspect ratio. The application scales the decoded coordinates independently across width and height to return to the original image.
Letterboxing preserves the aspect ratio. The application records the resize scale and padding, subtracts the padding from each decoded box, then divides by the scale. YOLOX-S anchors the resized image at the top left, so padding appears only below and to the right and the coordinate offsets are zero.
How Scene Detector runs an ExecuTorch detector
The supplied ExecuTorch detectors memory-map the imported .pte file, load its forward method, and check that the method declares the XNNPACK backend. Each detector converts the prepared bitmap to a channels-first float array and runs one inference call.
The model packages use INT8-quantized operations internally, but their application input and output tensors are float32. Quantization is part of the exported graph rather than an instruction to pass an INT8 bitmap from Java.
How Scene Detector runs a LiteRT detector
LiteRtYoloDetector.java uses LiteRT’s CompiledModel API from Java and selects CPU execution. The YOLO26 profiles set XNNPACK flags for forced FP16 execution. The weight-only profile also enables signed INT8 weight support.
YOLO26 accepts a float32 channels-first input and returns 300 six-value detection rows. YOLO11 uses an INT8 input with the scale and zero point required by the optimized package, then returns a float32 [1, 84, 8400] tensor.
How Scene Detector decodes YOLO boxes and class scores
YOLOv5, YOLOv8, YOLOv9, and YOLO11 output box coordinates as center x, center y, width, and height. The detector converts these values to left, top, right, and bottom coordinates. YOLO26 already returns left, top, right, and bottom coordinates.
YOLOv5 and YOLOX-S include a separate objectness value. YOLOv8 and YOLOv9 don’t. YOLOv9 also uses multi-label decoding, so one candidate can produce more than one class entry before filtering.
YOLOX-S returns raw prediction heads at strides 8, 16, and 32. Its detector adds each cell’s grid position to the predicted center offsets and multiplies by the stride. It exponentiates predicted widths and heights and multiplies them by the stride. It applies sigmoid to the objectness and class logits, multiplies objectness by the highest class probability, and maps retained boxes back to the original image.
The YOLOv5, YOLOv8, YOLOv9, and LiteRT profiles apply sigmoid only when scores fall outside [0, 1], indicating logits rather than probabilities. YOLOX-S always applies sigmoid because its separate prediction heads contain logits.
How Scene Detector handles duplicate detections
Several candidates can describe the same object. The application sorts candidates by score and applies per-class NMS:
  1. Keep the highest-scoring box.
  2. Compare lower-scoring boxes for the same class.
  3. Remove a box when its IoU with a kept box exceeds the model profile’s threshold.
  4. Continue until no candidates remain or the result reaches the maximum detection count.
DetectionOverlayView.java scales the retained boxes to the displayed bitmap or camera preview and draws the COCO label and confidence score.
How Scene Detector uses optimized Arm CPU kernels
The supplied ExecuTorch programs and LiteRT models use XNNPACK for CPU execution. XNNPACK integrates KleidiAI, which supplies optimized matrix multiplication and other compute kernels for Arm processors. On a compatible phone, the runtime can select suitable Arm-optimized kernels automatically for individual operations.
Some models on the Arm AI Portal state that they are optimized for Scalable Matrix Extension 2 (SME2) . SME2 is an Arm CPU instruction set extension for accelerating matrix-heavy operations used by AI and computer vision models.
An SME2 optimization label means that the model package and intended runtime provide an SME2-capable execution path. It doesn’t mean that every Android device supports SME2 or that every operation uses an SME2 kernel. The selected path still depends on the model, operation, runtime build, and CPU features.
How model-specific code is kept in adapters
DetectionAdapter.java is the boundary between MainActivity.java and a detection workflow. AdapterRegistry.java registers the supplied ExecuTorch and LiteRT object-detection adapters and reads GeneratedAdapterRegistry.java for build-time extensions.
Add another strategy when a model can keep the same runtime, task, import flow, and per-frame UI. Add a separate adapter when the runtime or model interaction changes, such as temporal tracking or a multi-frame input. A .pte or .tflite filename alone doesn’t prove that a model fits one of the supplied strategies.
You can now trace the application from model import through image preprocessing, ExecuTorch or LiteRT inference, model-specific decoding, NMS, and annotated output.
Next, you’ll learn how to extend Scene Detector to use an unsupported model.
