Run Arm AI Portal image classification models on Android
Set up the Android command-line tools for Photo Insight
Connect an Arm-based Android phone and run Photo Insight
Import and run Arm AI Portal image-classification models on Android
Understand the Photo Insight Android application
(Optional) Use a model not currently supported by Photo Insight
Enable Developer options and USB debugging, then run
adb devices -l. Confirm that your phone appears with the state device. If it reports unauthorized, unlock the phone and accept the debugging prompt. If it doesn’t appear, see
Run apps on a hardware device
.Select the mode that matches the runtime and task you want to use. LiteRT Quick Identify and ExecuTorch Quick Identify run fixed-label ImageNet classification. ExecuTorch CLIP Custom Match ranks candidate descriptions that you enter at run time.
Photo Insight formats the result according to the selected adapter. Fixed-label ImageNet models display ranked labels from their bundled label set. CLIP ranks the candidate descriptions that you enter at run time.
Fixed-label classification assigns an image to labels from a predefined set, such as ImageNet labels. Zero-shot CLIP classification compares the image with candidate descriptions that you provide at run time, so you can define the categories without retraining the model.
Compare the model’s task, runtime, methods, tensors, preprocessing, outputs, labels or tokenizer, and required assets with the supplied adapters. Register it only when all required elements match. If any required element differs, use the coding-agent workflow to generate and validate another adapter.
