Connect an Android phone
Enable Developer options and USB debugging on the phone. Connect the phone to your development computer with USB, unlock it, and accept the debugging authorization prompt.
Verify that your phone is listed in adb:
adb devices -l
The output lists the authorized phone and its device serial. If the phone reports unauthorized, unlock it and accept the debugging prompt. If the phone doesn’t appear, see Run apps on a hardware device .
Clone the application repository
Clone the repository with Git, then enter the project directory:
git clone https://github.com/arm-education/ai-portal-android-app-image-to-text.git
cd ai-portal-android-app-image-to-text
Run the remaining terminal commands from this project directory.
Prepare the Arm AI Portal model downloader
The sample repository includes a downloader for its supported Arm AI Portal model packages. The packages are published by Arm and hosted in Arm’s Hugging Face repositories.
Create a Python virtual environment and install the package used by the downloader:
python3 -m venv .hf-venv
.hf-venv/bin/python -m pip install --upgrade pip huggingface_hub
python -m venv .hf-venv
.\.hf-venv\Scripts\python.exe -m pip install --upgrade pip huggingface_hub
The later commands invoke the environment’s Python executable directly, so the PowerShell script-execution policy doesn’t need to be changed.
If Python reports that venv is unavailable on Debian or Ubuntu, install the python3-venv package and rerun the command.
Build and run the Photo Insight application
Use the Gradle wrapper to build and lint the debug APK:
chmod +x gradlew
./gradlew :app:assembleDebug :app:lintDebug
.\gradlew.bat :app:assembleDebug :app:lintDebug
You don’t need to install Gradle separately because the repository includes the wrapper.
Install the APK and start Photo Insight:
adb install -r app/build/outputs/apk/debug/app-debug.apk
adb shell am start -n org.arm.learningpath.imageclassification/.MainActivity
Photo Insight opens without a model. You can see its three workflows, but you can’t run any of them until you import their matching .tflite or .pte files.
Image Alt Text:Photo Insight first-launch screen with LiteRT Quick Identify selected and ExecuTorch Quick Identify beside it in the horizontal workflow selector. The empty photo area and Model setup needed message show that no model or image has been imported yet.Photo Insight before a model or photo is added
You’ve connected an Arm-based Android phone, prepared the model downloader, and confirmed that Photo Insight builds and starts.
Next, you’ll download an optimized image-classification model from the Arm AI Portal and classify a photo.
