Arm AI Portal
The Arm AI Portal is a catalog of AI models across different runtimes, use cases, and profiles that are optimized for different Arm-based targets. The AI Portal provides benchmarking and compatibility data, code examples, and deployment methods.
You’ll use an example application called Photo Insight to run various image classification models from the Arm AI Portal on an Arm-based Android device.
Check the host development tools
You’ll use a terminal and a physical Arm-based Android phone. The setup commands install the Android SDK and help you verify the development environment before you build the application.
Before you run the commands, ensure your development machine has the prerequisite tools installed.
Open a terminal. On Windows, use PowerShell.
Run the check for tools:
git --version
java -version
javac -version
python3 --version
python3 -m pip --version
curl --version
unzip -v
git --version
java -version
javac -version
python --version
python -m pip --version
$PSVersionTable.PSVersion
Install any missing host tools before continuing. The Java compiler version should be 17 or later.
Note
You can open the cloned project in Android Studio and run it on a connected phone or an Android Virtual Device (AVD). If you use an AVD, select a recent system image that supports the application’s arm64-v8a native libraries. An emulator is useful for functional testing, but its performance isn’t representative of a physical Arm-based phone.
Install the Android command-line tools
The following commands download Google’s Android SDK Command-Line Tools , verify the pinned archive checksum, and place the tools under ANDROID_HOME:
if [ -z "${ANDROID_HOME:-}" ]; then
    case "$(uname -s)" in
        Darwin) export ANDROID_HOME="$HOME/Library/Android/sdk" ;;
        Linux) export ANDROID_HOME="$HOME/Android/Sdk" ;;
        *) printf 'Unsupported operating system.\n' >&2; false ;;
    esac
fi
case "$(uname -s)-$(uname -m)" in
    Darwin-arm64)
        android_cli_archive="commandlinetools-mac_arm64-15859902_latest.zip"
        android_cli_sha256="835b62a26162b229b441d1f6d4680383815a270809eb33522c0d480fa5002c4e"
    Darwin-x86_64)
        android_cli_archive="commandlinetools-mac_x86_64-15859902_latest.zip"
        android_cli_sha256="c5a6378ab5cf7e0d5701921405115befff13e9ff7417fb588389338f8bd050f3"
    Linux-*)
        android_cli_archive="commandlinetools-linux-15859902_latest.zip"
        android_cli_sha256="4e4c464f145a7512b57d088ac6c278c03c9eea610886b35a5e0804e74eedf583"
    *) printf 'No Android command-line archive is configured for this computer.\n' >&2; false ;;
esac
android_cli_temp="$(mktemp -d)"
curl --fail --location \
    "https://dl.google.com/android/repository/$android_cli_archive" \
    --output "$android_cli_temp/$android_cli_archive"
if command -v sha256sum >/dev/null 2>&1; then
    printf '%s  %s\n' "$android_cli_sha256" "$android_cli_temp/$android_cli_archive" |
        sha256sum --check
else
        shasum -a 256 -c
fi
unzip -q "$android_cli_temp/$android_cli_archive" -d "$android_cli_temp"
mkdir -p "$ANDROID_HOME/cmdline-tools/latest"
cp -R "$android_cli_temp/cmdline-tools/." "$ANDROID_HOME/cmdline-tools/latest/"
export PATH="$ANDROID_HOME/cmdline-tools/latest/bin:$ANDROID_HOME/platform-tools:$PATH"
if (-not $env:ANDROID_HOME) {
    $env:ANDROID_HOME = "$env:LOCALAPPDATA\Android\Sdk"
$androidCliArchive = "commandlinetools-win-15859902_latest.zip"
$androidCliSha256 = "90ae805d20434428bffcb699c290860f19bb5f66a67e6b330067e3de801fb04a"
$androidCliTemp = Join-Path $env:TEMP "android-cli-$([guid]::NewGuid())"
$androidCliZip = Join-Path $androidCliTemp $androidCliArchive
New-Item -ItemType Directory -Path $androidCliTemp | Out-Null
Invoke-WebRequest `
    -Uri "https://dl.google.com/android/repository/$androidCliArchive" `
    -OutFile $androidCliZip
$downloadedSha256 = (Get-FileHash $androidCliZip -Algorithm SHA256).Hash
if ($downloadedSha256 -ne $androidCliSha256) {
    throw "Android command-line tools checksum verification failed."
Expand-Archive -Path $androidCliZip -DestinationPath $androidCliTemp
$latestTools = Join-Path $env:ANDROID_HOME "cmdline-tools\latest"
New-Item -ItemType Directory -Force -Path $latestTools | Out-Null
Copy-Item -Path "$androidCliTemp\cmdline-tools\*" `
    -Destination $latestTools -Recurse -Force
$env:Path = "$latestTools\bin;$env:ANDROID_HOME\platform-tools;$env:Path"
If you already have an SDK in ANDROID_HOME, the commands reuse that location.
The export commands and PowerShell environment assignments apply to the current terminal. Continue in the same terminal. If you use a new terminal, you’ll need to set ANDROID_HOME to the same directory and add cmdline-tools/latest/bin and platform-tools to PATH again.
Install and verify the required SDK packages
Review and accept the Android SDK licenses when prompted.
After accepting licenses, install Platform-Tools, Android SDK Platform 35, and Build-Tools 35.0.0:
sdkmanager --sdk_root="$ANDROID_HOME" --licenses
sdkmanager --sdk_root="$ANDROID_HOME" \
    "platform-tools" \
    "platforms;android-35" \
    "build-tools;35.0.0"
sdkmanager --version
adb version
test -d "$ANDROID_HOME/platforms/android-35"
test -d "$ANDROID_HOME/build-tools/35.0.0"
sdkmanager.bat "--sdk_root=$env:ANDROID_HOME" --licenses
sdkmanager.bat "--sdk_root=$env:ANDROID_HOME" `
    "platform-tools" `
    "platforms;android-35" `
sdkmanager.bat --version
adb version
Test-Path "$env:ANDROID_HOME\platforms\android-35"
Test-Path "$env:ANDROID_HOME\build-tools\35.0.0"
The final two checks return no output on macOS or Linux when the directories exist. On Windows, both checks should return True.
You’ve now installed the Android command-line tools and verified the required SDK packages.
Next, you’ll connect an Arm-based Android phone and build Photo Insight.
