Run Arm AI Portal Speech Transcription models on Android
Prepare the Android command-line tools for building Speech Journal
Connect an Arm-based Android device and run Speech Journal
Import and run Arm AI Portal speech recognition models on Android
Understand the Speech Journal Android application
(Optional) Use a model not currently supported by Speech Journal
Install Android SDK Platform 35, Platform-Tools, and Build-Tools 34.0.0. The sample project compiles against API 35 and supports Android 9 (API 28) or later.
Use Android Debug Bridge (
adb) from Android SDK Platform-Tools to confirm that the phone is authorized, uses the arm64-v8a ABI, and runs Android 9 (API 28) or later.Select Whisper Base · LiteRT for the first workflow and Whisper Tiny · ExecuTorch for the comparison. The app also provides the opportunity to experiment with other models pre-provided in the registry.
You record audio and receive an English transcript in a journal entry. Inference runs locally on the Android CPU, and your recording stays on the device.
Compare the model’s task, runtime, package files, callable methods or signatures, tensors, audio preprocessing, tokenizer, decoder behavior, and output format with the supplied adapters. Add a compatible model descriptor to
CompatibleModelRegistry.models(). For a new adapter, register its instance in GeneratedAdapterRegistry.adapters() and its descriptor in GeneratedAdapterRegistry.models(), then rebuild and test the app on your phone.
