Build an on-device AI fitness tutor app on Android
Set up AI Plank Tutor
Get pose landmarks from camera
Add scoring logic for the plank pose
Turn pose data into a prompt for the local LLM
Run the LLM locally with AI Chat
Connect coaching corrections to Android text-to-speech
Explore options for tuning and extending AI Plank Tutor
Open
ui/MainActivity.kt and replace the TODO in setUpCamera() with the provided ProcessCameraProvider snippet. When the provider is ready, the callback stores it and calls bindCameraUseCases().After CameraX initializes and binds its use cases, MediaPipe Pose Landmarker should produce landmarks for each frame. If the camera preview appears but no pose landmarks are detected, make sure that you granted camera
permission and that your full body is visible in the frame. Then, check Logcat for
PoseLandmarkerHelper errors. If the preview doesn’t appear, confirm that
bindCameraUseCases() runs after ProcessCameraProvider becomes available.data/PlankPoseData.kt contains referenceLandmarks for the instructor pose and angleWeights that set the importance of each joint. The app uses these values to calculate joint angles and a weighted score.ui/landmarker/PoseScoreHelper.kt maps angles to names with KEY_ANGLE_NAMES and formats the largest differences in angleDifference(). Use the filter and maxEntries parameters to set a threshold and limit the entries included in the prompt.Add
implementation("com.arm:ai-chat:0.1.0") to the dependencies block in app/build.gradle, then sync the project.
