# Run the LLM locally with AI Chat
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/)
- [Set up AI Plank Tutor](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/1-introduce-plank-tutor/)
- [Get pose landmarks from camera](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/2-camera-pose-landmarks/)
- [Add scoring logic for the plank pose](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/3-plank-score/)
- [Turn pose data into a prompt for the local LLM](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/4-data-to-prompt/)
- [Run the LLM locally with AI Chat](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/5-llm-ai-chat/)
- [Connect coaching corrections to Android text-to-speech](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/6-android-tts/)
- [Explore options for tuning and extending AI Plank Tutor](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/7-extend/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/_next-steps/)
## Add the AI Chat dependency
Open `app/build.gradle`.
Add the AI Chat dependency to the end of the `dependencies` block:
implementation("com.arm:ai-chat:0.1.0")
Sync the project with Gradle.
The AI Chat library provides the Android inference API used in this app and by the [Arm AI Chat app](https://play.google.com/store/apps/details?id=com.arm.aichat&hl=en_GB). The library uses `llama.cpp` for GGUF inference. `llama.cpp` integrates Arm [KleidiAI](https://developer.arm.com/ai/kleidi-libraries) kernels. Q4_0 GGUF models work particularly well with these kernels and can get strong acceleration on phones with [SME2](https://www.arm.com/technologies/sme2), SVE2, and Neon support.
The starter project already has `mavenCentral()` in `settings.gradle` and native library packaging configured in `app/build.gradle`, so adding the dependency is the only Gradle change you need to make.
## Add the model file to the device
The app expects a Q4_0 GGUF model file named `Phi-4-mini-instruct-Q4_0.gguf`.
Download [microsoft_Phi-4-mini-instruct-Q4_0.gguf](https://huggingface.co/bartowski/microsoft_Phi-4-mini-instruct-GGUF/blob/main/microsoft_Phi-4-mini-instruct-Q4_0.gguf) from Hugging Face. The model has 3.8 billion parameters, and its size is about 2.3 GB. Rename the downloaded file by removing the leading `microsoft_` prefix.
Keep at least 5 GB free on the device. The app imports the model from external app storage and then copies it into internal app storage the first time it loads, so the device temporarily needs room for both copies.
The provided `LlmModelStore.kt` helper looks for the model in a few import locations. The most useful location while developing is the app-specific external files directory `/sdcard/Android/data/com.arm.demo.AIPlankTutor/files/llm/Phi-4-mini-instruct-Q4_0.gguf`.
With your device connected over USB, first confirm that `adb` can see the phone:
adb devices
Your device is listed as `device`:
__output__
List of devices attached
__output__
<device-id>    device
If the device is listed as `unauthorized`, unlock the phone and accept the USB debugging prompt.
Next, create the app-specific external directory. This is the import location that `LlmModelStore` checks before copying the model into internal app storage:
adb shell mkdir -p /sdcard/Android/data/com.arm.demo.AIPlankTutor/files/llm
Then, push the model file from the directory where you downloaded and renamed it:
adb push Phi-4-mini-instruct-Q4_0.gguf /sdcard/Android/data/com.arm.demo.AIPlankTutor/files/llm/
> **Note**: The push can take a few minutes because the GGUF file is large. Don’t disconnect the device while the transfer is running.
When the app first loads the model, `LlmModelStore` checks that the file is readable and at least 2 GB. `LlmModelStore` then copies it into the app’s internal files directory. Later runs use the internal copy.
> **Note**: If the model can’t be found, check Logcat for `LlmModelStore`. The error message lists every model path that was checked.
## Wire AI Chat into MainActivity
Open `ui/MainActivity.kt`.
Add the following imports:
```kotlin
import androidx.lifecycle.ViewModel
import androidx.lifecycle.ViewModelProvider
import androidx.lifecycle.viewmodel.CreationExtras
import com.arm.aichat.AiChat
import com.arm.demo.AIPlankTutor.llm.LlmModelStore
import com.arm.demo.AIPlankTutor.ui.viewmodels.LlmViewModel
Add an `llmViewModel` property after the existing `mainViewModel` property:
```kotlin
private val mainViewModel: MainViewModel by viewModels()
private val llmViewModel: LlmViewModel by viewModels {
    object : ViewModelProvider.Factory {
        @Suppress("UNCHECKED_CAST")
        override fun <T : ViewModel> create(modelClass: Class<T>, extras: CreationExtras): T {
            val inferenceEngine = AiChat.getInferenceEngine(applicationContext)
            val modelStore = LlmModelStore(applicationContext)
            return LlmViewModel(inferenceEngine, modelStore) as T
`AiChat.getInferenceEngine()` creates a native-backed inference engine used by the ViewModel. `LlmModelStore` is the helper that finds or imports the GGUF model file. Now make the `LlmViewModel` accept those parameters.
## Add AI Chat to LlmViewModel
Open `LlmViewModel.kt`.
```kotlin
import android.util.Log
import androidx.lifecycle.viewModelScope
import com.arm.aichat.InferenceEngine
import kotlinx.coroutines.flow.onCompletion
import kotlinx.coroutines.launch
Change the class declaration so the ViewModel receives the AI Chat inference engine and model store:
```kotlin
class LlmViewModel(
    private val inferenceEngine: InferenceEngine,
    private val llmModelStore: LlmModelStore,
) : ViewModel() {
    // Code continues as before...
Add this `init` block at the very start of the class body:
```kotlin
init {
    viewModelScope.launch {
        _isBusy.emit(true)
        loadModelAndSystemPrompt()
        _isBusy.emit(false)
        _systemPromptProcessed.emit(true)
When the ViewModel is created, this block loads the model and sends the system prompt. The existing `_isBusy` state will also be used to avoid starting another LLM generation while one is already running.
## Load the model and system prompt
Replace the TODO in `loadModelAndSystemPrompt()` with the following code:
```kotlin
private suspend fun loadModelAndSystemPrompt() {
    val modelFile = llmModelStore.getModelFile()
    inferenceEngine.loadModel(modelFile.absolutePath)
    inferenceEngine.setSystemPrompt(TUTOR_SYSTEM_PROMPT)
You can read `TUTOR_SYSTEM_PROMPT` at the bottom of the file. The system prompt tells the model to act as a concise yoga teacher, use the joint-angle facts, and return one short correction.
`loadModel()` parses the GGUF file and allocates the model in memory, so it can take noticeable time on the first run. The system prompt is set once after the model loads, so each later user prompt can stay focused on the live pose differences.
## Send a prompt to AI Chat
Replace the TODO in `sendUserPrompt()` with the following code:
```kotlin
fun sendUserPrompt(
    plainTextMessage: String,
    generationLimit: Int = LLM_GENERATION_LIMIT,
    if (_isBusy.value) return
        if (_isBusy.value) return@launch
        Log.d(TAG, "Sending:\n$plainTextMessage")
        _isBusy.emit(true)
        var tokenCount = 0
        inferenceEngine.sendUserPrompt(plainTextMessage, predictLength = generationLimit)
            .onCompletion { cause ->
                _isBusy.emit(false)
                if (sentence.isNotEmpty()) {
                    _tokens.emit(".")
                if (cause != null) {
                    Log.d(TAG, ">= Token collection aborted! $cause")
                } else if (tokenCount == 0) {
                    Log.d(TAG, ">= No tokens collected!")
                } else {
                    Log.d(TAG, ">= Token collection complete.")
            .collect { token ->
                tokenCount++
                _tokens.emit(token)
The two `_isBusy` checks prevent the app from starting a second generation if a new prompt arrives just before image analysis is disabled. The `onCompletion` block emits a final full stop if the model stops before ending the current sentence. That lets the sentence splitter flush the last partial sentence.
## Split streamed tokens into sentences
AI Chat returns a stream of tokens. Android text-to-speech works better with complete phrases or sentences, so split the stream before sending it to the speech pipeline.
Replace the TODO in the `sentences` Flow with this code:
```kotlin
val sentences: Flow<Sentence> = _tokens
    .filterNot { it.isNewLine() }
    .map { word ->
        if (sentence.isEmpty()) {
            if (word.isPunctuation()) return@map null
        sentence.append(if (sentence.isEmpty()) word.trimStart() else word)
        if (sentence.isNotEmpty() && word.isPunctuation()) {
            sentence.run {
                toString().also { setLength(0) }
        } else null
    .filterNotNull()
    .map { text -> Sentence(text) }
    .flowOn(Dispatchers.Default)
The ViewModel now exposes a `Flow<Sentence>` instead of raw tokens. In the next section, you’ll collect this Flow and send each sentence to Android text-to-speech.
## Release the inference engine
The AI Chat engine owns native resources. Add the following cleanup function inside `LlmViewModel`:
```kotlin
override fun onCleared() {
    inferenceEngine.destroy()
    super.onCleared()
Android calls `onCleared()` when the ViewModel is no longer used, which gives the app a clear place to release the native inference engine.
## Send pose prompts to the LLM
Return to `MainActivity.kt`.
In the previous section, you logged each pose prompt to Logcat. Replace the temporary prompt collector in `collectAppState()` with the following version:
```kotlin
launch {
    mainViewModel.userPosePrompt.collect {
        if (imageAnalysisEnabled && llmViewModel.systemPromptProcessed.value) {
            llmViewModel.sendUserPrompt(it.first)
Add another collector to pause image analysis while the model is busy:
```kotlin
launch {
    llmViewModel.isBusy.collect {
        imageAnalysisEnabled = !it
This prevents the app from generating a new prompt for every camera frame while the LLM is already responding. On-device LLM generation is much slower than camera frame delivery, so this backpressure step is what keeps the feedback loop reasonable.
Finally, add a temporary sentence collector so you can show the generated correction in the caption area and check it in Logcat:
```kotlin
launch {
    llmViewModel.sentences.collect { sentence ->
        captionTextView.text = sentence.text
        captionTextView.visibility = View.VISIBLE
        Log.d(TAG, "Tutor correction: ${sentence.text}")
You’ll replace this direct caption update with `SpeechManager` when you set up Android text-to-speech, so the caption stays synchronized with text-to-speech playback.
## Run the app
Build and run the app on your Android device. Expect the tutor’s advice at the bottom of the screen.
To see what’s happening behind the scenes, open Logcat and filter for `LlmViewModel` or `MainActivity`. The app should load the model, send pose prompts, and print short tutor corrections.
The first run can take longer because the model file might be copied into the app’s internal storage and loaded into memory. Later runs should start faster. If model loading fails, also filter Logcat for `LlmModelStore` to print the exact import paths it checked.
## What you’ve accomplished and what’s next
You’ve now added Arm’s AI Chat library and used it to run a local GGUF model on the Android device. The app produces short text coaching corrections and shows them as captions.
Next, you’ll add speech output to the app using Android `TextToSpeech`.
