# Get pose landmarks from camera
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/)
- [Set up AI Plank Tutor](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/1-introduce-plank-tutor/)
- [Get pose landmarks from camera](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/2-camera-pose-landmarks/)
- [Add scoring logic for the plank pose](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/3-plank-score/)
- [Turn pose data into a prompt for the local LLM](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/4-data-to-prompt/)
- [Run the LLM locally with AI Chat](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/5-llm-ai-chat/)
- [Connect coaching corrections to Android text-to-speech](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/6-android-tts/)
- [Explore options for tuning and extending AI Plank Tutor](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/7-extend/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/ai-plank-tutor/_next-steps/)
## Configure CameraX
Open `ui/MainActivity.kt`.
The starter project already requests camera permission and calls `setUpCamera()` from `onCreate()`. Replace the TODO in `setUpCamera()` with the following code:
```kotlin
private fun setUpCamera() {
    val cameraProviderFuture = ProcessCameraProvider.getInstance(this)
    cameraProviderFuture.addListener({
        cameraProvider = cameraProviderFuture.get()
        bindCameraUseCases()
    }, Dispatchers.Main.asExecutor())
`ProcessCameraProvider` owns the camera use cases for the activity. When the provider is ready, the app stores it and calls `bindCameraUseCases()`.
## Bind preview and image analysis
The app needs two CameraX use cases:
- `Preview`, which displays the camera feed in the `PreviewView`.
- `ImageAnalysis`, which receives frames for pose detection.
In `MainActivity.kt`, replace the TODO at the end of `bindCameraUseCases()` with the following code:
```kotlin
val preview = Preview.Builder()
    .setResolutionSelector(resolutionSelector)
    .setTargetRotation(targetRotation)
    .build()
val imageAnalyzer = ImageAnalysis.Builder()
    .setBackpressureStrategy(ImageAnalysis.STRATEGY_KEEP_ONLY_LATEST)
    .setOutputImageFormat(ImageAnalysis.OUTPUT_IMAGE_FORMAT_RGBA_8888)
    .build()
    .also {
        it.setAnalyzer(
            Dispatchers.Default.limitedParallelism(1).asExecutor()) { image ->
            detectPose(image)
cameraProvider.unbindAll()
try {
    cameraProvider.bindToLifecycle(
        this, cameraSelector, preview, imageAnalyzer
    preview.surfaceProvider = cameraPreview.surfaceProvider
} catch (exc: Exception) {
    Log.e(TAG, "Use case binding failed", exc)
The analyzer uses `STRATEGY_KEEP_ONLY_LATEST` because pose detection should work on the most recent frame. If the device is busy, old frames are dropped instead of queued.
The output image format is `RGBA_8888`, which makes the frame data easy to copy into a `Bitmap` before passing it to MediaPipe.
The analyzer runs on a background executor with one worker. That keeps camera frame conversion off the UI thread and serializes calls into the landmarker helper, which is useful because live-stream inference is driven by timestamped frames.
## Send frames to the landmarker
In `bindCameraUseCases()`, you set `ImageAnalysis` to call `detectPose()` for every analyzed frame. Now, replace the TODO in `detectPose()` with the following code:
```kotlin
private fun detectPose(imageProxy: ImageProxy) {
    if (!this::poseLandmarkerHelper.isInitialized || poseLandmarkerHelper.isClosed) {
        imageProxy.close()
        return
    if (imageAnalysisEnabled) {
        poseLandmarkerHelper.detectLiveStream(
            imageProxy = imageProxy,
            isFrontCamera = true
    } else {
        imageProxy.close()
The code checks that the MediaPipe helper is ready before using it. If the helper isn’t ready, it closes the `ImageProxy` immediately.
> **Note**
> Every `ImageProxy` from CameraX must be closed. In this app, `PoseLandmarkerHelper.detectLiveStream()` closes the image after copying its pixels. If the frame is skipped, `detectPose()` closes it directly.
Now replace the TODO in `onResults()` with this code:
```kotlin
override fun onResults(landmarks: List<NormalizedLandmark?>) {
    mainViewModel.handleUserPose(landmarks)
The code is a callback from `PoseLandmarkerHelper`, and it sends the live landmarks onto the ViewModel. You’ll convert those landmarks into joint angles and a pose score.
## Configure MediaPipe Pose Landmarker
To configure what happens between `detectPose()` and `onResults()`, open `ui/landmarker/PoseLandmarkerHelper.kt`.
The starter file already contains the MediaPipe imports, model path, confidence values, and the `LandmarkerListener` interface for the callbacks to `MainActivity`.
Replace the TODO in `setupPoseLandmarker()` with the following code:
```kotlin
fun setupPoseLandmarker(context: Context) {
    try {
        val baseOptions = BaseOptions.builder()
            .setDelegate(Delegate.GPU)
            .setModelAssetPath(MODEL_PATH)
            .build()
        val options = PoseLandmarker.PoseLandmarkerOptions.builder()
            .setBaseOptions(baseOptions)
            .setNumPoses(1)
            .setMinPoseDetectionConfidence(MIN_POSE_DETECTION_CONFIDENCE)
            .setMinTrackingConfidence(MIN_POSE_TRACKING_CONFIDENCE)
            .setMinPosePresenceConfidence(MIN_POSE_PRESENCE_CONFIDENCE)
            .setRunningMode(RunningMode.LIVE_STREAM)
            .setResultListener(this::returnLiveStreamResult)
            .setErrorListener(this::returnLiveStreamError)
            .build()
        poseLandmarker = PoseLandmarker.createFromOptions(context, options)
    } catch (exception: IllegalStateException) {
        listener.onError("Pose Landmarker failed to initialize. See logs for details.")
        Log.e(TAG, "MediaPipe failed to load the pose landmarker", exception)
    } catch (exception: RuntimeException) {
        Log.e(TAG, "MediaPipe failed to create the pose landmarker", exception)
The app uses `RunningMode.LIVE_STREAM` because frames arrive continuously from the camera. In this mode, MediaPipe returns results through callbacks instead of returning them directly from the detection call.
The app also requests one pose with `setNumPoses(1)`. This keeps the example focused on a single learner.
The `Delegate.GPU` option asks MediaPipe to use the device GPU for the pose model. If initialization fails on a particular device, the error listener and Logcat message are the first places to check.
## Convert camera frames to MPImage
When you call from `MainActivity`, it’s with a CameraX `ImageProxy`, but the MediaPipe analyzer expects an `MPImage`.
Replace the TODO in `detectLiveStream()` with the following code to convert between the two and start the Pose Landmarker analysis:
```kotlin
fun detectLiveStream(
    imageProxy: ImageProxy,
    isFrontCamera: Boolean
    val frameTime = SystemClock.uptimeMillis()
    val imageWidth = imageProxy.width
    val imageHeight = imageProxy.height
    val rotationDegrees = imageProxy.imageInfo.rotationDegrees
    val bitmapBuffer = Bitmap.createBitmap(
        imageWidth,
        imageHeight,
        Bitmap.Config.ARGB_8888
    imageProxy.use { image ->
        bitmapBuffer.copyPixelsFromBuffer(image.planes[0].buffer)
    val matrix = Matrix().apply {
        postRotate(rotationDegrees.toFloat())
        if (isFrontCamera) {
            postScale(-1f, 1f, imageWidth.toFloat(), imageHeight.toFloat())
    val rotatedBitmap = Bitmap.createBitmap(
        bitmapBuffer,
        0,
        0,
        bitmapBuffer.width,
        bitmapBuffer.height,
        matrix,
        true
    val mpImage = BitmapImageBuilder(rotatedBitmap).build()
    poseLandmarker?.detectAsync(mpImage, frameTime)
The call to `imageProxy.use { ... }` closes the frame after its pixels are copied.
The matrix rotates the image using the camera frame metadata. For the front camera, it also mirrors the image so the detected pose matches the preview the learner sees.
`SystemClock.uptimeMillis()` provides a monotonic timestamp for the frame. MediaPipe requires timestamps for video and live-stream inputs, and `detectAsync()` returns immediately; the result arrives later through the result listener.
## Return the first detected pose
Finally, replace the TODO in `returnLiveStreamResult()` with the following code:
```kotlin
private fun returnLiveStreamResult(
    result: PoseLandmarkerResult,
    @Suppress("UNUSED_PARAMETER") input: MPImage
    listener.onResults(result.landmarks().firstOrNull())
MediaPipe returns a list of detected poses. The app asks for one pose, so it forwards only the first landmark list.
## Run the app
Build and run the app on your Android device.
When prompted, allow camera access. Expect to see the front camera preview in the right side of the app.
The score won’t update yet. At this point, the app is collecting pose landmarks and passing them to `MainViewModel`.
If the preview opens but no landmarks are produced later, make sure your full body is visible in the frame and check Logcat for `PoseLandmarkerHelper`.
## What you’ve accomplished and what’s next
You’ve now connected the Android camera to the MediaPipe pose landmarker. The app opens the front camera and passes live pose landmarks into the app.
Next, you’ll add pose scoring logic to the app.
