Accelerate Denoising, Background Blur and Low-Light Camera Effects with SME2
Benchmark mode
The application you built earlier includes a benchmark mode that runs the core processing loop multiple times in a hot loop:
  • ai-camera-pipelines/bin/cinematic_mode_benchmark
  • ai-camera-pipelines/bin/low_light_image_enhancement_benchmark
  • ai-camera-pipelines/bin/neural_denoiser_temporal_benchmark_4K
These benchmarks demonstrate the performance improvements enabled by KleidiCV and KleidiAI:
  • KleidiCV enhances OpenCV performance with computation kernels optimized for Arm processors.
  • KleidiAI accelerates LiteRT+XNNPack inference using AI-optimized micro-kernels tailored for Arm CPUs.
Performance with SME
You can run the benchmarks using the applications you built earlier (with SME2 support).
Run the Background Blur benchmark:
bin/cinematic_mode_benchmark 20 --tflite_file resources/depth_and_saliency_v3_2_assortedv2_w_augment_mobilenetv2_int8_only_ptq.tflite
The output is similar to:
        INFO: Frame rate throttling is turned OFF
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
INFO: Total run time over 20 iterations: 614.724 ms
INFO: Average FPS: 32.5349
Run the Low Light Enhancement benchmark:
bin/low_light_image_enhancement_benchmark 20 --tflite_file resources/HDRNetLIME_lr_coeffs_v1_1_0_mixed_low_light_perceptual_l1_loss_float32.tflite
INFO: Total run time over 20 iterations: 57.3958 ms
INFO: Average FPS: 348.457
Last, run the Neural Denoising benchmark:
bin/neural_denoiser_temporal_benchmark_4K 20
INFO: Total run time over 20 iterations: 36.2114 ms
INFO: Average FPS: 552.312
From these results, you can see that:
  • cinematic_mode_benchmark performed 20 iterations in 614.724 ms, which means 32.5349 FPS
  • low_light_image_enhancement_benchmark performed 20 iterations in 57.3958 ms, which means 348.457 FPS
  • neural_denoiser_temporal_benchmark_4K performed 20 iterations in 36.2114 ms, which means 552.312 FPS
Performance without SME2
To measure the performances without the benefits of SME2, set ENABLE_SME2=0 and recompile the pipelines as shown in the build page.
You can now re-run the benchmarks and compare the performance benefits of using SME2.
Example performance with a Vivo X300 Android phone
The table table shows the measurements (in FPS, Frames Per Second) measured on a Vivo X300 android phone:
BenchmarkWithout SME2With SME2Uplift
cinematic_mode_benchmark1727+58.8%
low_light_image_enhancement_benchmark5184+64.70%
neural_denoiser_temporal_benchmark_4K (temporal only)249678+172.3%
neural_denoiser_temporal_benchmark_4K (spatio-temporal)-87
Note
The Android system enforces throttling, so your own results may vary slightly.
As shown, SME2 brings a dramatic performance improvement. This new power also enables to use much more complex processing algorithms like the spatio-temporal denoising.
