Apply transformations
In the previous section, you built the AI Camera Pipelines. In this section, you’ll run them to apply transformations to an input image or input frames.
cd $HOME/ai-camera-pipelines
python3 -m venv venv
. venv/bin/activate
pip install numpy opencv-python pillow torch
Background blur
Run the background Blur pipeline, using resources/test_input.png as the input image and write the transformed image to test_output_cinematic_mode.png:
bin/cinematic_mode resources/test_input.png test_output_cinematic_mode.png resources/depth_and_saliency_v3_2_assortedv2_w_augment_mobilenetv2_int8_only_ptq.tflite
Image Alt Text:example image alt-textInput image Image Alt Text:example image alt-textImage with blur applied
Low-Light Enhancement
Run the Low-Light Enhancement pipeline, using resources/test_input.png as the input image and write the transformed image to test_output_lime.png:
bin/low_light_image_enhancement resources/test_input.png test_output_lime.png resources/HDRNetLIME_lr_coeffs_v1_1_0_mixed_low_light_perceptual_l1_loss_float32.tflite
Image Alt Text:example image alt-textInput image Image Alt Text:example image alt-textImage with low-light enhancement applied
Neural denoising
When the SME extension is not available, only temporal neural denoising is available, so this is what you will run for now — but stay tuned as the SME extension will become available very soon:
./scripts/run_neural_denoiser_temporal.sh
The input frames are:
  • first converted from .png files in the resources/test-lab-sequence/ directory to the sensor format (RGGB Bayer) into neural_denoiser_io/input_noisy*
  • those frames are then processed by the Neural Denoiser and written into neural_denoiser_io/output_denoised*
  • last, the denoised frames are converted back to .png for easy visualization in directory test-lab-sequence-out
Image Alt Text:example image alt-textOriginal frame Image Alt Text:example image alt-textFrame with temporal denoising applied
