Accelerate Denoising, Background Blur and Low-Light Camera Effects with SME2
Download the AI camera pipelines project
Clone the project repository:
git clone https://git.gitlab.arm.com/kleidi/kleidi-examples/ai-camera-pipelines.git ai-camera-pipelines.git
Fetch the required large files using Git LFS:
cd ai-camera-pipelines.git
git lfs install
git lfs pull
Create a build container
Build the Docker container used to compile the pipelines:
docker build -t ai-camera-pipelines -f docker/Dockerfile \
  --build-arg DOCKERHUB_MIRROR=docker.io \
  --build-arg CI_UID=$(id -u) \
  docker/
Build the AI camera pipelines
Start a shell in the container you just built:
docker run --rm --volume $PWD:/home/cv-examples/example -it ai-camera-pipelines
Inside the container, run the following commands:
ENABLE_SME2=1
TENSORFLOW_GIT_TAG="v2.20.0"
# Build flatbuffers
git clone https://github.com/google/flatbuffers.git
cd flatbuffers
git checkout v24.3.25
mkdir build
cd build
cmake -GNinja -DCMAKE_INSTALL_PREFIX=../install ..
cmake --build .
cmake --install .
cd ../..
# Build the pipelines
mkdir build
cd build
cmake -GNinja -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=../install -DTENSORFLOW_GIT_TAG=$TENSORFLOW_GIT_TAG -DTFLITE_HOST_TOOLS_DIR=../flatbuffers/install/bin -DENABLE_SME2=$ENABLE_SME2 -DCMAKE_TOOLCHAIN_FILE=../example/toolchain.cmake -S ../example
cmake --build .
cmake --install .
# Package and export the pipelines.
cd ..
tar cfz example/install.tar.gz install
Leave the container by pressing Ctrl+D.
Note
In the above cmake command line, you’ll note that the pipelines are build with SME2 (-DENABLE_SME2=$ENABLE_SME2), but that this could be disabled as well. We will use this feature later when benchmarking the performance improvements brought by SME2.
Install the pipelines
cd $HOME
tar xfz ai-camera-pipelines.git/install.tar.gz
mv install ai-camera-pipelines
Dive deeper into the AI camera pipelines
The AI camera pipelines repository contains more information in its README file should you wish to dive deeper into it.
