Arm Scalable Matrix Extension (SME) is an architecture extension that provides enhanced support for matrix operations. SME builds on the Scalable Vector Extensions (SVE and SVE2), adding new capabilities to efficiently process matrices.
Key features include:
SME defines the following new features:
This makes SME and SME2 particularly fit for image processing. In this learning path, you will use SME2 instructions thru the KleidiAI and KleidiCV libraries:
KleidiAI is an open-source library of optimized, performance-critical routines (micro-kernels) for AI workloads on Arm CPUs. These routines are tuned for specific Arm microarchitectures to maximize performance and are designed for straightforward integration into C/C++ ML and AI frameworks.
Several popular AI frameworks already take advantage of KleidiAI to improve performance on Arm platforms.
KleidiCV is an open-source library that provides high-performance image-processing functions for AArch64. It is lightweight and simple to integrate, and computer-vision frameworks such as OpenCV can leverage KleidiCV to accelerate image processing on Arm devices.
This Learning Path provides three example applications that combine AI and computer vision (CV) techniques:
The applications:
The background blur pipeline is implemented as follows:
Background blur pipeline
The low-light enhancement pipeline is adapted from the LiveHDR+ method proposed by Google Research (2017):
Low-light enhancement pipeline
The low-resolution coefficient-prediction network (implemented with LiteRT) performs operations such as:
Every smartphone photographer has experienced it: images that look sharp in daylight but degrade in dim lighting. This is because signal-to-noise ratio (SNR) drops sharply when sensors capture fewer photons. At 1000 lux, the signal dominates and images look clean; at 1 lux, readout noise becomes visible as grain, color speckling, and loss of fine detail.
That’s why neural camera denoising is a critical, computationally-demanding, stage in modern camera pipelines. Done well, it can transform noisy frames into sharp, vibrant captures; done poorly, it leaves smudges and artifacts.
As shown below, the neural-denoising pipeline uses two algorithms:
ultralite in the repository (uses a history of previous frames)collapsenet in the repository
Neural denoising pipeline
The Neural Denoising application works on frames, as emitted by a camera sensor in Bayer format:
