Request fixed-rate compression
Compression is specified at image creation time. To request fixed-rate compression, provide a VkImageCompressionControlEXT structure to the pNext chain of VkImageCreateInfo:
VkImageCompressionControlEXT compression_control{VK_STRUCTURE_TYPE_IMAGE_COMPRESSION_CONTROL_EXT};
compression_control.flags = VK_IMAGE_COMPRESSION_FIXED_RATE_DEFAULT_EXT;
image_create_info.pNext = &compression_control;
Note that these are the same VkImageCompressionControlEXT and VkImageCreateInfo structures used in the previous step.
The image may then be created:
VkImage image_handle;
vkCreateImage(get_device().get_handle(), &image_create_info, nullptr, &image_handle);
This requests default fixed-rate compression (which depends on the device). On Arm GPUs, it is the highest supported bitrate that is the highest possible quality.
To request a specific bitrate (after confirming that it is supported, as shown in the previous step), you may instead use VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT like this:
VkImageCompressionFixedRateFlagsEXT fixed_rate_flags_array[1] = {VK_IMAGE_COMPRESSION_FIXED_RATE_2BPC_BIT_EXT};
compression_control.flags                        = VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT;
compression_control.compressionControlPlaneCount = 1;
compression_control.pFixedRateFlags              = &fixed_rate_flags_array[0];
image_format_info.pNext = &compression_control;
This example requests a fixed rate of 2 bits per component.
