The Vulkan extension VK_EXT_image_compression_control may be used to verify if default compression (such as AFBC) was applied, and to request fixed-rate compression.
Swapchain images are a special case, and additionally require the VK_EXT_image_compression_control_swapchain extension.
In your application, you may use
vkEnumerateDeviceExtensionProperties
to check if the device supports the extension, and, if so, include it in
VkDeviceCreateInfo
’s ppEnabledExtensionNames before calling
vkCreateDevice
In the Vulkan Samples framework, this can be handled in the sample’s constructor with this helper function:
afrc::afrc()
add_device_extension(VK_EXT_IMAGE_COMPRESSION_CONTROL_EXTENSION_NAME);
If a device supports the extension, it does not mean that it also supports fixed-rate compression of images. The extension may still be used to verify if the images use default (lossless) compression.
Before compressing a VkImage, you need to use the extension to query if any given image, with its particular format and usage properties, supports fixed-rate compression, as shown in the next step.
