Explore related resources
Give feedback
AI-assisted
Close
How do I check whether my device supports the required Vulkan extensions?
Call vkEnumerateDeviceExtensionProperties and look for VK_EXT_image_compression_control. If present, add it to VkDeviceCreateInfo.ppEnabledExtensionNames before vkCreateDevice.
What should I do differently for swapchain images?
Swapchain images also require VK_EXT_image_compression_control_swapchain. Enable this extension in addition to VK_EXT_image_compression_control if you want fixed-rate compression on swapchain images.
Can I follow this Learning Path without creating a new Vulkan sample?
Yes. You can use your own Vulkan application and refer to the Khronos Vulkan Samples code as a reference.
How do I know if a specific image configuration supports fixed-rate compression?
Populate VkImageCreateInfo with your format, image type, tiling, and usage, then use these properties to query support before creating the image. If supported, proceed to request fixed-rate compression.
How do I request and verify that fixed-rate compression is applied?
Provide a VkImageCompressionControlEXT with VK_IMAGE_COMPRESSION_FIXED_RATE_DEFAULT_EXT in the pNext chain of VkImageCreateInfo when creating the image. Use VK_EXT_image_compression_control to inspect the compression state and confirm that fixed-rate compression is active.
Return to Mobile, Graphics, and Gaming
