The record command spawns the process and pins it to the core specified by the -c option. You can either use --pe_file to let WindowsPerf know which process to spawn or simply add the process to spawn at the very end of the wperf command.
This simplifies the steps presented in the previous example.
If you want to pass command line arguments to your application, you can call them after all of the WindowsPerf options. All command line arguments are going to be passed verbatim to the program that is being spawned. If you want to execute the CPython example above using this approach, you could just type:
wperf record -e ld_spec:100000 -c 1 --timeout 30 -- python_d.exe -c 10**10**100
This command will automatically spawn the process python_d.exe -c 10**10**100 (and pass command line options to it), sample for 30 seconds with --timeout 30 event ld_spec with sample frequency of 100000.
You should see the same output from this command as in the previous section.
