# Configure your development tools
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/)
- [Configure your development tools](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/get-started/)
- [Use the counting feature](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/counting-feature/)
- [Use the sampling feature](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/sampling-feature/)
- [Next Steps](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/_next-steps/)
## Which development tools do I need to use WindowsPerf with Visual Studio?
Four development tools are recommended if you want to use WindowsPerf for performance analysis on a Windows on Arm computer.
Each tool has an install guide explaining how to install and configure it.
Use the install guides to install and configure each tool before getting started:
- [Visual Studio 2022 Community Edition](https://learn.arm.com/install-guides/vs-woa/)
- [WindowsPerf](https://learn.arm.com/install-guides/wperf/)
- [Visual Studio extension for WindowsPerf](https://learn.arm.com/install-guides/windows-perf-vs-extension/)
- [Windows Performance Analyzer (WPA) plugin](https://learn.arm.com/install-guides/windows-perf-wpa-plugin/)
## How can I try out the WindowsPerf features in Visual Studio?
You can use the code example below to demonstrate WindowsPerf features in Visual Studio.
Create a new C++ Console App named `App1` in Visual Studio.
Remove the provided code and replace it with the code below:
```cpp
#include <iostream>
#include <vector>
#include <chrono>
const int N = 10000; // Matrix size
void fillRowWise(std::vector<std::vector<int>>& matrix) {
    for (int i = 0; i < N; ++i) {
        for (int j = 0; j < N; ++j) {
            matrix[i][j] = i + j;
void fillColumnWise(std::vector<std::vector<int>>& matrix) {
int main() {
    std::vector<std::vector<int>> matrix(N, std::vector<int>(N, 0));
    // Measure row-wise traversal
    auto start = std::chrono::high_resolution_clock::now();
    fillRowWise(matrix);
    auto end = std::chrono::high_resolution_clock::now();
    std::cout << "Row-wise fill time: "
              << std::chrono::duration_cast<std::chrono::milliseconds>(end - start).count()
              << " ms" << std::endl;
    // Measure column-wise traversal
    fillColumnWise(matrix);
    std::cout << "Column-wise fill time: "
    return 0;
The example code shows the difference between filling a matrix in a different order. You will see that column-wise traversal is much slower than row-wise traversal. This happens because:
- Row-wise access follows how memory is stored in contiguous blocks.
- Column-wise access jumps across rows, causing frequent cache misses.
On the `Build` menu select `Build Solution` to generate `App1.exe`.
Run the program by opening the `Debug` menu and select `Start Without Debugging`.
This will run the debug build for the program.
The console output is shown below:
![Image Alt Text:Run Debug](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/debug.png)
Change the Visual Studio target to `Release` instead of `Debug` and build the solution again.
The console output shows shorter execution time due to compiler optimizations.
Here is the new output:
![Image Alt Text:Run Release](https://learn.arm.com/learning-paths/laptops-and-desktops/windowsperf-vs-extension/release.png)
