# Setup GitHub Self-hosted Runner
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/laptops-and-desktops/windows_cicd_github/)
- [Setup GitHub Self-hosted Runner](https://learn.arm.com/learning-paths/laptops-and-desktops/windows_cicd_github/runner-setup/)
- [Create and run simple workflow](https://learn.arm.com/learning-paths/laptops-and-desktops/windows_cicd_github/runner-run/)
- [Next Steps](https://learn.arm.com/learning-paths/laptops-and-desktops/windows_cicd_github/_next-steps/)
You will learn how to setup a GitHub [self-hosted runner](https://docs.github.com/en/actions/hosting-your-own-runners/about-self-hosted-runners) on a [Windows on Arm](https://learning-paths/laptops-and-desktops/intro/) machine or [cloud instance](https://learning-paths/cross-platform/woa_azure/).
You will need a valid [GitHub](https://github.com) account to complete this Learning Path.
## Create a new GitHub repository
You can create a new repository in GitHub to test a simple `hello world` command running on the Windows Arm VM using GitHub Actions for CI/CD.
In a browser, log in using your GitHub account. Select the [New Button](https://github.com/new) to create a new repository. Give the repository a name. Click `Create Repository`.
## Prepare GitHub self-hosted runner
Runners are the machines that execute the jobs in the GitHub Actions workflow.
Select the `Settings` tab in your currently empty repository. On the left pane, select `Actions->Runners`.
On the `Runners` page, select the `New self-hosted runner` button. You will be presented with options to choose the Operating system and architecture for your runner. Select `Windows` and `ARM64`. The instructions to download and configure your Windows Arm runner are displayed (the exact commands will be unique to you).
## Enable self-hosted runner
In your Windows on Arm machine, open a `PowerShell` window. Copy and paste each of the above commands. When prompted, it is OK to select default configuration options.
On the execution of the last command (`./run.cmd`) you will see output similar the below:
__output__
√ Connected to GitHub
__output__
Current runner version: '2.303.0'
__output__
<timestamp>: Listening for Jobs
Return to the `Actions->Runners` page in your GitHub repository and you should now see your runner displayed similar to the below:
![Image Alt Text:ghrunner2](/learning-paths/laptops-and-desktops/windows_cicd_github/images/ghrunner_2.png)
You are now ready to test a simple CI/CD GitHub Actions workflow on your Windows on Arm runner.
