# Platform-specificity of the Python packages
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/laptops-and-desktops/win_python/)
- [Platform-specificity of the Python packages](https://learn.arm.com/learning-paths/laptops-and-desktops/win_python/how-to-1/)
- [Build the application](https://learn.arm.com/learning-paths/laptops-and-desktops/win_python/how-to-2/)
- [Next Steps](https://learn.arm.com/learning-paths/laptops-and-desktops/win_python/_next-steps/)
## Python on Arm
Arm-native build tools are provided to enable the developers to create Arm64 apps using different technologies, including C/C++, .NET or even Python. More specifically, Python can be useful to rapidly prototype complex solutions that can be used for many purposes, including scientific/numerical computing, signal and image processing, training and optimizing machine learning models. As many of those tasks require extensive computations, having the Arm support enables us to boost the application performance with an optimized power consumption.
The official Python implementation and its standard library is provided by CPython. It compiles code into bytecode before interpretation, enabling it to contain platform-specific code.
Starting from Python v3.11, native support for Arm devices running Windows 11 is available. To use this feature, you just install a dedicated Arm64 Python package. There is no change to your scripts. However, as described below, there can be some build or porting requirements for the dependent pip packages, especially when you rely on the platform-specific dependencies.
In this learning path you will see how this works for the popular NumPy package on Python 3.12.
## Before you begin
Before going further, let’s make sure you have installed Python v3.12 using the following installation packages:
1. [x64](https://www.python.org/ftp/python/3.12.0/python-3.12.0-amd64.exe)
2. [Arm64](https://www.python.org/ftp/python/3.12.0/python-3.12.0-arm64.exe)
Install Python v3.12 for Arm64 and x64. The installation process is the same as described in [Python on Windows on Arm](https://developer.arm.com/documentation/102528/0100/Install-Visual-Studio).
To run the Python interpreter for x64, open the command prompt and type the following command:
py -3.12-64
The output will be similar to the following one:
__output__Python 3.12.0 (tags/v3.12.0:0fb18b0, Oct  2 2023, 13:03:39) [MSC v.1935 64 bit (AMD64)] on win32
__output__Type "help", "copyright", "credits" or "license" for more information.
__output__>>>
Press CTRL+Z or type **exit()** to leave the interpreter.
Similarly, you can use the Python interpreter for Arm64:
py -3.12-arm64
The above command generates the following output:
__output__Python 3.12.0 (tags/v3.12.0:0fb18b0, Oct  2 2023, 13:15:47) [MSC v.1935 64 bit (ARM64)] on win32
__output__>>>
Again, close it using the CTRL+Z or the **exit()** command.
> **Note:** By comparing the output of the two Python interpreters, we can see that both interpreters use the MSC v.1935 compiler for both x64 (labeled as AMD64) or Arm64 (labeled ARM64).
## Python packages
Because x64 and Arm64-based Python use different underlying C compilers, the Python packages can have compatibility and porting issues. Traditionally, you install Python packages using pip, which automatically installs the dependencies. First, pip tries to find the platform-independent package (called the wheel). Then, it looks for the platform-specific package and eventually builds it from the source code.
If you are writing Python packages to take advantage of Arm64, you must ensure you compile your packages for Arm64, not x64. This is not a problem for pure (platform-independent) Python packages.
You will now see what this means in practice by installing the NumPy package using pip.
Open the command prompt and type the following command to ensure you use the latest pip version:
py -3.12-arm64 -m pip install --upgrade pip
The output will look as follows:
__output__Requirement already satisfied: pip in c:\users\db\appdata\local\programs\python\python312-arm64\lib\site-packages (23.2.1)
__output__Collecting pip
__output__  Obtaining dependency information for pip from https://files.pythonhosted.org/packages/47/6a/453160888fab7c6a432a6e25f8afe6256d0d9f2cbd25971021da6491d899/pip-23.3.1-py3-none-any.whl.metadata
__output__  Downloading pip-23.3.1-py3-none-any.whl.metadata (3.5 kB)
__output__Downloading pip-23.3.1-py3-none-any.whl (2.1 MB)
__output__   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 3.0 MB/s eta 0:00:00
__output__Installing collected packages: pip
__output__  Attempting uninstall: pip
__output__    Found existing installation: pip 23.2.1
__output__    Uninstalling pip-23.2.1:
__output__      Successfully uninstalled pip-23.2.1
__output__Successfully installed pip-23.3.1
Repeat the same for x64:
py -3.12-64 -m pip install --upgrade pip
Now, try to install the NumPy package, which you will use later on to implement the sample application. To install NumPy, type:
py -3.12-arm64 -m pip install numpy
The command will generate the following output:
__output__Collecting numpy
__output__  Downloading numpy-1.26.2.tar.gz (15.7 MB)
__output__     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 15.7/15.7 MB 3.2 MB/s eta 0:00:00
__output__  Installing build dependencies ... done
__output__  Getting requirements to build wheel ... done
__output__  Installing backend dependencies ... done
__output__  Preparing metadata (pyproject.toml) ... error
__output__  error: subprocess-exited-with-error
__output__
__output__  × Preparing metadata (pyproject.toml) did not run successfully.
__output__  │ exit code: 1
__output__  ╰─> [21 lines of output]
__output__      + C:\Users\db\AppData\Local\Programs\Python\Python312-arm64\python.exe C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78\vendored-meson\meson\meson.py setup C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78 C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78\.mesonpy-2y9byjdq\build -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md --native-file=C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78\.mesonpy-2y9byjdq\build\meson-python-native-file.ini
__output__      The Meson build system
__output__      Version: 1.2.99
__output__      Source dir: C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78
__output__      Build dir: C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78\.mesonpy-2y9byjdq\build
__output__      Build type: native build
__output__      Project name: NumPy
__output__      Project version: 1.26.2
__output__      WARNING: Failed to activate VS environment: Could not find C:\Program Files (x86)\Microsoft Visual Studio\Installer\vswhere.exe
__output__
__output__      ..\..\meson.build:1:0: ERROR: Unknown compiler(s): [['icl'], ['cl'], ['cc'], ['gcc'], ['clang'], ['clang-cl'], ['pgcc']]
__output__      The following exception(s) were encountered:
__output__      Running `icl ""` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `cl /?` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `cc --version` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `gcc --version` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `clang --version` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `clang-cl /?` gave "[WinError 2] The system cannot find the file specified"
__output__      Running `pgcc --version` gave "[WinError 2] The system cannot find the file specified"
__output__
__output__      A full log can be found at C:\Users\db\AppData\Local\Temp\pip-install-z7o5tmzj\numpy_a28e0fc1b6724727af70f23c6ac2be78\.mesonpy-2y9byjdq\build\meson-logs\meson-log.txt
__output__      [end of output]
__output__
__output__  note: This error originates from a subprocess, and is likely not a problem with pip.
We can see that the installation has failed. For Arm64, there is no platform-specific wheel. So, pip downloads and tries to build the package from the source code to create the local Arm64 package wheel. However, as you do not have the build tools yet, the installation was not successful.
Before going any further, try to install NumPy for x64 by invoking the following command:
py -3.12-64 -m pip install numpy
For x64 there is a platform-specific wheel available so the installation is successful, which is confirmed by the command output:
__output__  Downloading numpy-1.26.2-cp312-cp312-win_amd64.whl.metadata (61 kB)
__output__     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.2/61.2 kB 467.6 kB/s eta 0:00:00
__output__Downloading numpy-1.26.2-cp312-cp312-win_amd64.whl (15.5 MB)
__output__   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 15.5/15.5 MB 2.5 MB/s eta 0:00:00
__output__Installing collected packages: numpy
__output__Successfully installed numpy-1.26.2
## Arm build tools
To install the NumPy package, we will need to provide the Arm build tools. Install Visual Studio 2022 Community with the **Desktop development with C++** workload and **Arm build tools** as explained in the [Visual Studio installation guide](https://developer.arm.com/documentation/102528/0100/Install-Visual-Studio).
After installing the build tools, restart your machine and install NumPy package with the following command:
Now, the installation will be successful and you will see the following output:
__output__Collecting numpy        Using cached numpy-1.26.2.tar.gz (15.7 MB)        Installing build dependencies ... done
__output__  Preparing metadata (pyproject.toml) ... done
__output__Building wheels for collected packages: numpy
__output__  Building wheel for numpy (pyproject.toml) ... done
__output__  Created wheel for numpy: filename=numpy-1.26.2-cp312-cp312-win_arm64.whl size=16845040 sha256=01f831dde6b7d4dc7729bf1c894af3ea5f3808a401a6c059451b3e55f66e143e
__output__  Stored in directory: c:\users\db\appdata\local\pip\cache\wheels\95\2f\43\2ca1fa1956ac9cb61ca696a9924ed5333df1d1b3ce9013f5d4
__output__Successfully built numpy
## Summary
You have just learned how pip can build the package from the source code and when the platform-independent package (called the wheel) is unavailable. In the next section, you will use the NumPy package to build the application.
