Give feedback
AI-assisted
Close
Which command prompt should I use to run the build steps on Windows on Arm?
Open ARM64 Native Tools Command Prompt. Start PowerShell from there if needed, then navigate to your project directory before running build and benchmark steps.
What result should I capture from the baseline run?
Record the benchmark measurements for the division routine. You’ll compare the same benchmark after rebuilding with PGO.
How do I compare baseline and PGO results?
Run the same division benchmark before and after rebuilding with the collected profile data. Keep the benchmark setup consistent, then compare the reported measurements to evaluate the impact of PGO.
How do I know that profile data was collected and applied?
Build an instrumented binary, run it to generate the execution profile, then rebuild using that profile. If you skip the run, the optimized build won’t use profile information, and your comparison won’t reflect PGO.
Why do the Learning Path benchmark integer division?
Division has higher latency and lower throughput than simple arithmetic on most CPU architectures, including Arm. The operation provides a clear baseline to observe the effect of PGO on a costlier operation.
Return to Laptops and Desktops
