Before you begin
Any Windows on Arm computer which has the required tools installed can be used for this Learning Path.
Follow the links to install the required tools.
Install the .NET desktop development workload component with Visual Studio. You can do this either during the initial installation or modify your existing installation.
To modify your existing installation of Visual Studio:
  1. Open the Windows Start Menu. Search for Visual Studio Installer and launch it.
  2. Select Modify.
Image Alt Text: img1
  1. On the Workloads tab, click on the .NET desktop development checkbox and then select Modify.
Image Alt Text: img2
After the installation completes, close the installer.
Compile a WPF application natively on Windows on Arm with .NET 6 framework
This Learning Path uses a sample Windows Presentation Foundation (WPF) application that solves a well-known algorithmic problem: the Traveling Salesman Problem .
This sample application is chosen because it is CPU intensive, and makes use of graphics to test the capabilities of WPF in .NET 6.
The sample application source code is configured to build and compile using .NET 5. In this Learning Path, you will port the application to .NET 6 which includes support for WPF on Arm.
To compile and run this WPF application using .NET 6 on a Windows on Arm device, follow the steps outlined below:
  1. Open Visual Studio on your Windows on Arm computer.
  2. Select Clone a repository from the Get Started options in Visual Studio as shown in the image below:
Image Alt Text: img3
  1. In the Repository location field enter https://github.com/GVerelst/TravelingSalesman
  2. Enter an appropriate Path where you would like to clone the repository on your machine. In this example, it is C:\TravelingSalesman. Then select Clone.
Image Alt Text: img4
  1. After the repository is cloned, 3 projects are displayed in the Solution Explorer pane.
  2. Right click on the TSP.WPF project and select Properties.
  3. In the General section, change the Target framework from .NET 5.0 to .NET 6.0 as shown in the image:
Image Alt Text: img5
  1. Save the changes to the project (Ctrl+S)
  2. In Solution Explorer, right-click the TSP.WPF project and select Publish. The Publish dialog appears.
  3. Under Target, click Folder then click Next, as shown in the following image:
Image Alt Text: img6
  1. Under Specific target, click Folder then click Next, as shown in the following image:
Image Alt Text: img7
  1. Select a location to store the generated binaries. You can leave the default folder selection as is and select Finish.
  2. The initial publish profile is created. Select Close.
  3. Click on Show all settings to display the Profile settings dialog.
Image Alt Text: img8
  1. Change the Target runtime from Portable to win-arm64 and click Save.
Image Alt Text: img9
  1. Click Publish. Visual Studio compiles a version of the project that is native executable on Arm devices as shown in the image below:
Image Alt Text: img10
  1. You should see a message that Publish succeeded. Click on Open Folder to view the generated binaries including the TSP.WPF application.
Image Alt Text: img11
Run the WPF application on your Windows on Arm device
Now that you have built the sample application for Windows on Arm, you are ready to run the executable.
Double-click TSP.WPF to run the application. The application starts as shown:
Image Alt Text: img12
You can change the inputs on the application as needed. Click Generate Path followed by Start to see the application run.
You have successfully run a WPF application built with the .NET 6 framework on a Windows on Arm device.
