Start by creating the static website. To do this, create a new folder, for example, named IoTPage. Within the IoTPage folder, create three further (and essential) files:
These files will serve as the backbone of your static website.
Open index.html and modify it as follows:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>IoTPage</title>
<link rel="stylesheet" href="styles.css">
</head>
<body>
<div class="container">
<h1>Temperature</h1>
<button id="fetchTemperatureButton">Get Temperature</button>
<div id="temperatureDisplay" class="display-box">Temperature will be displayed here</div>
</div>
<script src="index.js"></script>
</body>
</html>
The above declarations link to an external CSS file (styles.css) which styles the webpage. The body of the website contains a heading called “Temperature”, a “Get Temperature” button which, when clicked, will fetch the temperature using the AWS Lambda function, and a display box where the fetched temperature will be shown.
Finally, the declarations link to an external JavaScript file (index.js) which will handle the button click and fetch the temperature data.
Next, open the styles.css file and modify it as follows:
body {
font-family: Arial, sans-serif;
display: flex;
justify-content: center;
align-items: center;
height: 100vh;
background-color: #f0f0f0;
margin: 0;
.container {
text-align: center;
background: white;
padding: 20px;
border-radius: 8px;
box-shadow: 0 4px 8px rgba(0,0,0,0.1);
button {
background-color: #4CAF50;
color: white;
border: none;
padding: 10px 20px;
text-align: center;
text-decoration: none;
display: inline-block;
font-size: 16px;
margin: 10px 0;
cursor: pointer;
border-radius: 5px;
button:hover {
background-color: #45a049;
.display-box {
margin-top: 20px;
padding: 15px;
border: 1px solid #ddd;
border-radius: 4px;
background-color: #fafafa;
The first part of the declaration relates to the body of the document. It sets the font to Arial or a sans-serif alternative. You use flexbox to center content both vertically and horizontally. The height is set to 100% of the viewport height. Also, the declarations will apply a light gray background color, and remove the default margin.
Then, there is a declaration of the .container class. It does the following:
Next, you have a declaration of the button style, which does the following:
A CSS file also styles the button element when it’s hovered over by darkening the green background color.
Finally, you have the .display-box class, which will do the following:
This CSS file provides a clean, centered, and modern look for the webpage with distinct styling for buttons and display boxes, enhancing the user experience.
After declaring the CSS you will implement the index.js file as follows:
document.getElementById('fetchTemperatureButton').addEventListener('click', function() {
fetch('YOUR_API_GATEWAY_ENDPOINT_URL')
.then(response => response.json())
.then(data => {
const temperature = data.average.toFixed(2);
document.getElementById('temperatureDisplay').innerText = `Average Temperature: ${temperature} °C`;
.catch(error => {
console.error('Error fetching temperature:', error);
document.getElementById('temperatureDisplay').innerText = 'Error fetching temperature';
After saving all the files, open the index.html file in a web browser. It should render as follows:
The website is now ready. However, to fetch temperatures, you will need to add the Lambda endpoint. You will configure this in the next section.
