What you've learned
You should now know how to:
  • Describe how to use AWS Lambda for IoT applications running on Arm64.
  • Process data from IoT devices.
  • Describe the serverless compute services in AWS.
  • Describe the notification services in AWS.
Knowledge Check
What is AWS Lambda?
Does Amazon SNS require you to set up the notification server?
What are policies for?
