Use Amazon DynamoDB for your IoT applications running on Arm64
What you've learned
You should now know how to:
  • Gain familiarity with Amazon DynamoDB.
  • Be able to run the IoT application that streams data to AWS IoT Core.
  • Be able to create the rule that parses messages from AWS IoT Core and writes them to DynamoDB.
Knowledge Check
What is the Rules Engine?
Does Amazon DynamoDB require you to set up the database server?
What is partitioning used for?
