Log an issue
Fork and edit
Discuss on Discord
AWS IoT Core
Connect the emulator to AWS IoT Core and stream data
Testing the data stream
Review
You should now know how to:
Does AWS IoT Core use MQTT protocol?
Can you use the device's certificate to manage device permissions in AWS IoT Core?
What do you use to connect a device to the AWS IoT Core?
You need to answer each question to see the results.
