Automate Windows on Arm virtual machine deployment with QEMU and KVM
Check system requirements
Understand and customize Windows on Arm VM automation scripts
Create a Windows on Arm virtual machine
Run a Windows on Arm virtual machine
Run
./create-win11-vm.sh all <vm-directory>. The command applies the default parameters and performs all creation steps automatically.The VM data is stored in the directory that you pass to the creation script. For example,
./create-win11-vm.sh all $HOME/win11-vm stores all VM files under $HOME/win11-vm.Windows installs automatically after the VM is created. Wait for installation to finish before proceeding to regular use.
Run
./run-win11-vm.sh <vm-directory>. The script checks if the VM is running, starts it in headless mode if needed, and connects over RDP using Remmina.Confirm you used the same VM directory you created earlier and that the VM files exist there. Re-run the launch script. The script detects if the VM is already running and will reconnect if possible.
