Overview
To understand how well your application performs, you can measure its system resource usage (such as CPU time and memory) without needing to look inside the code. In this Learning Path, you’ll learn how to collect resource usage data using a simple script. This helps you compare performance between different builds and see how efficiently your system runs each version.
The example application you will use is FFmpeg, a tool set that performs video encode and decode tasks. You will run the same tests with both the x86_64 binary (using Windows instruction emulation) and the Arm64 native binary on a Windows on Arm computer.
Download the packages
You don’t need to compile FFmpeg from source. You can download the pre-built binaries to begin your testing:
Unzip the downloaded packages
Once you’ve downloaded both packages, unzip them. You’ll find the binaries in the bin folder inside each package. The x86_64 version is for emulation, while the Arm64 version runs natively on your Windows on Arm device. Double-check the folder names so you don’t mix them up.
Note
It’s a good idea to create a separate folder for each version. Make a note of where you put both ffmpeg.exe and ffplay.exe for each version as you’ll need these paths soon to run your tests and compare results.
Now you’re set up with both versions of FFmpeg. Next, you’ll use these binaries to encode a video and see how each one performs.
Download the video source
For this test, you’ll use a sample video called RaceNight. Download it from this RaceNight public dataset .
Unzip the package and make a note of the path to the .yuv file inside.
Encode the video
The video you downloaded is in .yuv raw format. This means it’s uncompressed and ready for processing, so no decoding step is needed. To test your system’s performance, you’ll use FFmpeg to compress the video with the x265 encoder and convert it to an .mp4 file. This workflow lets you measure how efficiently each FFmpeg binary handles video encoding on your Windows on Arm device.
Assuming everything is in your current directory, open a terminal and run this command:
ffmpeg-n7.1.1-56-gc2184b65d2-win64-gpl-7.1\ffmpeg-n7.1.1-56-gc2184b65d2-win64-gpl-7.1\bin\ffmpeg.exe -f rawvideo -pix_fmt yuv420p -s 3840x2160 -r 50 -i RaceNight_3840x2160_50fps_420_8bit_YUV_RAW\RaceNight_3840x2160_50fps_8bit.yuv -vf scale=1920:1080 -c:v libx265 -preset medium -crf 20 RaceNight_1080p.mp4 -benchmark -stats -report
Note
Make sure to update the paths to ffmpeg.exe and the yuv. video file to match where you saved them.
This command resizes the video and compresses it into an MP4 file using H.265 encoding (using the x265 encoder). The -benchmark option shows performance stats while the encoding runs. When it’s done, you’ll have a new file called RaceNight_1080p.mp4.
Try running the command with both the x86_64 and Arm64 versions of FFmpeg. Then, compare the results to see which one is faster.
View the results
Here’s what the output looks like for the x86_64 version of ffmpeg.exe:
        x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp
x265 [info]: tools: b-intra strong-intra-smoothing lslices=6 deblock sao
Output #0, mp4, to 'RaceNight_1080p.mp4':
  Metadata:
    encoder         : Lavf61.7.100
  Stream #0:0: Video: hevc (hev1 / 0x31766568), yuv420p(tv, progressive), 1920x1080, q=2-31, 50 fps, 12800 tbn
      Metadata:
        encoder         : Lavc61.19.101 libx265
      Side data:
        cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A
[out#0/mp4 @ 0000020e0d6f3880] video:13297KiB audio:0KiB subtitle:0KiB other streams:0KiB global headers:2KiB muxing overhead: 0.079970%
frame=  600 fps=8.4 q=29.4 Lsize=   13308KiB time=00:00:11.96 bitrate=9115.2kbits/s speed=0.167x
bench: utime=480.344s stime=10.203s rtime=71.548s
bench: maxrss=910112KiB
x265 [info]: frame I:      3, Avg QP:22.41  kb/s: 50202.13
x265 [info]: frame P:    146, Avg QP:23.73  kb/s: 18265.18
x265 [info]: frame B:    451, Avg QP:28.45  kb/s: 5827.62
x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
encoded 600 frames in 71.51s (8.39 fps), 9075.96 kb/s, Avg QP:27.27
And here’s the output from the Arm64 native version:
  Metadata:
      Metadata:
      Side data:
[out#0/mp4 @ 000001b3c215f8e0] video:13348KiB audio:0KiB subtitle:0KiB other streams:0KiB global headers:2KiB muxing overhead: 0.080169%
frame=  600 fps= 23 q=29.3 Lsize=   13359KiB time=00:00:11.96 bitrate=9150.2kbits/s speed=0.456x
bench: utime=169.891s stime=7.281s rtime=26.224s
bench: maxrss=1040836KiB
x265 [info]: frame I:      3, Avg QP:22.40  kb/s: 50457.20
x265 [info]: frame P:    146, Avg QP:23.71  kb/s: 18246.21
x265 [info]: frame B:    451, Avg QP:28.40  kb/s: 5878.38
encoded 600 frames in 26.20s (22.90 fps), 9110.78 kb/s, Avg QP:27.23
Check out the last line in each output. The run time and frames per second show how each build performed. The Arm64 version is much faster, thanks to running natively on your hardware.
Review your progress and compare performance
You’ve successfully set up both x86_64 and Arm64 versions of FFmpeg, downloaded a sample video, and encoded it using each binary on your Windows on Arm device. By comparing the output, you’ve seen firsthand how native Arm64 performance outpaces emulated x86_64. This gives you a solid foundation for deeper resource usage analysis in the next section.
