# Build OpenCV Applications with Clang
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/)
- [OpenCV and Compilers for Windows on Arm](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/1-opencv-compilers/)
- [Setup](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/1.5-opencv-setup/)
- [Build OpenCV Applications with Clang](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/2-2-build-clang/)
- [Build OpenCV Applications with MSVC](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/2-1-build-msvc/)
- [Next Steps](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/_next-steps/)
Follow the steps below to build OpenCV and a test application using the library with the Clang compiler.
## Clone the OpenCV repository
Open up a Windows PowerShell and checkout the source tree:
git clone [https://github.com/opencv/opencv](https://github.com/opencv/opencv)
cd opencv
git checkout tags/4.10.0
> You might be able to use a later version, but these steps have been tested with the version 4.10.0.
## Pre-build configuration
You can use CMake from the command line.
First, run the following command to run the pre-build configuration.
mkdir build_clang
cd build_clang
cmake \
  -S .. \
  -B . \
  -G "Ninja" \
  -DCMAKE_C_COMPILER=clang \
  -DCMAKE_CXX_COMPILER=clang++ \
  -DCMAKE_BUILD_TYPE=Release \
  -DBUILD_opencv_world=ON \
  -DWITH_ITT=OFF \
  -DWITH_OPENCL=OFF \
  -DWITH_OPENCLAMDBLAS=OFF \
  -DWITH_OPENCLAMDFFT=OFF \
  -DWITH_OPENCL_D3D11_NV=OFF \
  -DWITH_DIRECTML=OFF \
  -DWITH_DIRECTX=OFF \
  -DWITH_ADE=OFF \
  -DWITH_CAROTENE=OFF
The given options specify the following:
- The source code is located one level above the current directory.
- The build will be performed in the current directory.
- The Clang compiler will be used as the compiler.
- The compiled library is generated as a single file that includes all of OpenCV’s functionality.
- Unnecessary options have been disabled, assuming processing on Arm CPUs.
If the configuration is successful, a message similar to the following should be displayed at the end of the execution:
-- General configuration for OpenCV 4.10.0 =====================================
--   Version control:               4.10.0
--   Platform:
--     Timestamp:                   2024-11-08T09:23:57Z
--     Host:                        Windows 10.0.22631 ARM64
--     CMake:                       3.28.1
--     CMake generator:             Ninja
--     CMake build tool:            C:/Users/username/work/venv/Scripts/ninja.exe
--     Configuration:               Release
--   CPU/HW features:
--     Baseline:                    NEON
--       requested:                 NEON FP16
--     Dispatched code generation:  NEON_DOTPROD NEON_FP16 NEON_BF16
--       requested:                 NEON_FP16 NEON_BF16 NEON_DOTPROD
--       NEON_DOTPROD (1 files):    + NEON_DOTPROD
--       NEON_FP16 (2 files):       + NEON_FP16
--       NEON_BF16 (0 files):       + NEON_BF16
--   C/C++:
--     Built as dynamic libs?:      YES
--     C++ standard:                11
--     C++ Compiler:                C:/Program Files/LLVM/bin/clang++.exe  (ver 18.1.8)
--     C Compiler:                  C:/Program Files/LLVM/bin/clang.exe
--   Install to:                    C:/Users/username/work/opencv/build_clang/install
-- Configuring done (244.5s)
-- Generating done (1.4s)
-- Build files have been written to: C:/Users/username/work/opencv/build_clang
## Build and install
Run the following commands to build and install OpenCV:
ninja
ninja install
> The build takes approximately 25 mins on a Lenovo X13s.
When the build and the install steps are complete, confirm the shared library has been created by inspecting the results in the `install/bin` directory:
ls ./install/bin
Also inspect the `install/lib` directory:
ls ./install/lib
The library used in your application is `opencv_world<version>.lib/dll`.
Once the library files are correctly generated, run the following command to ensure there are no errors.
./install/bin/opencv_version.exe
## Build OpenCV Applications
Once the OpenCV library has been successfully created, you can create a simple application and try using it.
### Prepare an application program
First, use a text editor to save the following C++ program as `test_opencv.cpp` in the `build_clang` directory.
```cpp
#include <opencv2/opencv.hpp>
#include <iostream>
int main() {
    cv::Mat image = cv::Mat::zeros(100, 100, CV_8UC3);
    if (image.empty()) {
        std::cout << "Failed to create an image!" << std::endl;
        return -1;
    cv::circle(image, cv::Point(50, 50), 30, cv::Scalar(255, 0, 0), -1);
    cv::imwrite("test_image.png", image);
    cv::waitKey(0);
    return 0;
This program is a simple example that uses OpenCV to create a 100x100 black image, draw a blue circle on it, and save it as a file.
### Compile the program
Compile the code using the command below:
clang++ ./test_opencv.cpp -o test_opencv.exe -I./install/include -L./install/lib -lopencv_world4100
- **`-o`**: Specifies the name of the generated executable file.
- **`-I`**: Indicates the directory where the OpenCV header files to be included are located.
- **`-L`**: Specifies the directory where the libraries for linking are located.
- **`-l`**: Specifies the name of the library to link. When linking `opencv_world4100.lib`, omit the `.lib` extension and specify it as `-lopencv_world4100`.
### Run the program
To run the executable, you need to ensure that the directory containing the dynamic libraries (DLLs) is added to the `PATH` environment variable, or place the DLLs in the same location as the executable.
> The command below adds the DLL directory to the beginning of the `PATH` environment variable. Since this is a temporary setting, the `PATH` will revert to its original state when the PowerShell session is closed. To set it permanently, you need to use the Windows system settings or the `[Environment]::SetEnvironmentVariable()` method.
$env:PATH = "./install/bin;" + $env:PATH
Run the test program:
./test_opencv.exe
When you execute the command, it will finish quickly, and `test_image.png` is generated. If you do not have the DLL directory in your search path, the program appears to run, but no `test_image.png` is generated.
Open the image file; it should look like the example shown below.
![test_image.png](https://learn.arm.com/learning-paths/laptops-and-desktops/win-opencv/2-2-build-clang/test_image.png)
Congratulations! You are now ready to create your own OpenCV applications using Clang.
