Give feedback
AI-assisted
Close
How do I validate the exported FP32 model?
Run python scripts/prepare_inputs.py and python scripts/validate_pte.py. Confirm that the output reports Accuracy gate passed and points to the FP32 validation report.
Where are the FP32 artifacts saved, and how can I change the location?
The artifacts are saved under artifacts/fp32 when you use the default configuration. To change the location, set SMOLVLA_ARTIFACTS_DIR to an absolute path and use the same location for the FP32 benchmark.
How do I reuse the same inputs for both FP32 and INT8 comparisons?
Generate deterministic inputs with the provided script and note the saved input-suite path. Pass that path to the INT8 pipeline with --input-suite, or set the SMOLVLA_INPUT_SUITE environment variable to use it.
How do I confirm that the INT8 pipeline succeeded?
Run the pipeline script and confirm that it ends with [8/8] Native accuracy gate passed. The script stores the artifacts in artifacts/int8. Use --output-dir to choose another location.
How do I validate the native runner against the PyTorch model?
Run ./scripts/run_runner.sh, then run python scripts/validate_runner.py. Confirm that the output says Native split orchestrator output matches the full PyTorch reference.
Return to Laptops and Desktops
