Convert the FP32 model
You’ll now work through the model conversion pipeline and validate the converted model output.
The scripts place the artifacts in artifacts/fp32 by default. To use a different location, set SMOLVLA_ARTIFACTS_DIR to an absolute path:
export SMOLVLA_ARTIFACTS_DIR="/path/to/artifacts/dir"
If you override the path, use the same location in the FP32 benchmark command later.
Generate inputs
First, generate and save deterministic tensor inputs. You’ll reuse the inputs when you compare the FP32 and INT8 models:
python scripts/generate_inputs.py \
    --synthetic-inputs \
    --checkpoint "$SMOLVLA_CHECKPOINT" \
    --output-dir "$SMOLVLA_INPUT_SUITE" \
    --image-size 512 \
    --language-length 48
The env.sh file sets default paths for SMOLVLA_CHECKPOINT and SMOLVLA_INPUT_SUITE. You can override the paths in the same way.
Export the model graph
The checkpoint stores many weights in BF16, but this ExecuTorch and XNNPACK workflow primarily supports FP16 and FP32. Convert the model to FP32 to provide broad backend coverage.
Load the FP32 PyTorch model, split it into vision, prefix and denoise, and export the graphs with torch.export:
python scripts/export.py \
    --input-suite "$SMOLVLA_INPUT_SUITE" \
    --variant fp32
Partition and lower the model
Convert each graph to ExecuTorch Edge IR, partition supported operators for XNNPACK, lower the graphs, and convert them to an ExecuTorch runtime .pte format:
python scripts/lower.py
Validate the export in the Python runtime
Check that the model converted correctly with ExecuTorch’s portable Python runtime binding.
Convert the input tensors into the serialized format used by the three exports:
python scripts/prepare_inputs.py
python scripts/validate_pte.py
After conversion, check that the exports collectively reproduce the PyTorch reference output.
The expected output is similar to:
        Accuracy gate passed; report: /path/to/artifacts/fp32/validation.json
Build the orchestrator
The setup built the ExecuTorch runtime with the XNNPACK backend and KleidiAI support.
ExecuTorch’s generic runner executes a single .pte program. Invoking the program separately for each stage would write and transfer intermediate tensors between processes. Repeatedly launching the program for ten denoising steps would also reload it each time, adding runtime overhead.
Build the provided C++ orchestrator and link it against the ExecuTorch runtime:
./scripts/build_runner.sh
The orchestrator loads the three exported .pte programs and keeps intermediate tensors in memory. It connects their inputs and outputs, then invokes denoising_step ten times in the same process.
Run the model on the target CPU
Run the model on the target Arm CPU with the native runner:
./scripts/run_runner.sh
Validate the native runner output against the original PyTorch reference:
python scripts/validate_runner.py
The expected output ends with:
        Native split orchestrator output matches the full PyTorch reference.
You’ve exported the FP32 SmolVLA, built a native runner for the target Arm CPU, and validated its output.
Next, you’ll quantize part of the model to INT8 and convert that model to ExecuTorch using the pipeline. You’ll then compare it to the FP32 variant through the same native runner.
