Install the required tools
Install git to clone the ExecuTorch repository, curl to fetch project files, and a C++ build toolchain:
sudo apt update
sudo apt install -y \
    git \
    curl \
    build-essential
The project uses Python 3.12. Install uv and use it to install Python 3.12 independently of the Python version provided by your Ubuntu release:
curl -LsSf https://astral.sh/uv/install.sh | sh
source "$HOME/.local/bin/env"
uv python install 3.12
Confirm that Python 3.12 is available:
python3.12 --version
The output is similar to:
        Python 3.12.14
Download the project files
Create a working directory and download the project files for this Learning Path:
mkdir -p smolvla-executorch-conversion-work
cd smolvla-executorch-conversion-work
curl -fL --retry 3 \
    -o smolvla-executorch-conversion.tar.gz \
    'https://gitlab.arm.com/learning-code-examples/code-examples/-/archive/main/code-examples-main.tar.gz?path=learning-paths/laptops-and-desktops/smolvla-executorch-conversion'
tar xfz smolvla-executorch-conversion.tar.gz \
    --strip-components=4 \
    -C smolvla-executorch-conversion
Set up the software environment
The setup.sh script does the following:
  • Creates a project-local virtual environment in .venv
  • Pins ExecuTorch v1.4.1 at commit e4d02f41f7909e8ed5bf4a14ffc520d733453d9f
  • Builds the ExecuTorch and XNNPACK runtime libraries with KleidiAI support and the Python bindings
  • Installs the required Python packages
  • Downloads the pinned SmolVLA checkpoint from Hugging Face
Run the setup script:
./scripts/setup.sh
The script downloads several gigabytes and compiles native libraries. The download can take 30 minutes or longer on systems with a small number of CPU cores.
Activate the virtual environment and resolve repository-local path variables:
source env.sh
Verify the resources
Verify the pinned packages, ExecuTorch revision and Python binding, XNNPACK runtime build with KleidiAI support, and SmolVLA checkpoint files:
python scripts/check_environment.py
The output of a successful check is similar to:
        Environment OK: aarch64, ExecuTorch e4d02f41
  Python: /path/to/smolvla-executorch-conversion/.venv/bin/python
  ExecuTorch: /path/to/smolvla-executorch-conversion/toolchain/executorch
  Runtime: /path/to/smolvla-executorch-conversion/toolchain/executorch/cmake-out-xnnpack
  Checkpoint: /path/to/smolvla-executorch-conversion/checkpoints/smolvla_base
You’ve downloaded the scripts to convert the model, built the ExecuTorch runtime, and configured your environment.
Next, you’ll export and lower the FP32 SmolVLA for an Arm CPU and validate the converted model against the PyTorch reference.
