After configuring permissions, pull and run the pre-built PyTorch container as shown in the setup step. If it runs without permission errors, Docker is configured correctly.
The path fine-tunes Llama 3.2 3B using
Llama3_3B_full_finetuning.py. The The path uses the 8B example only to illustrate why fine-tuning improves factual responses.Use a JSONL dataset prepared for supervised fine-tuning. Ensure its fields match what the script loads; check the dataset loading section in the training script to align names and structure.
The process produces a fine-tuned Llama model that the testing step can load with vLLM. If you’re able to serve the model in the vLLM container without errors, the fine-tuning completed successfully.
On Raspberry Pi datasheet questions, the fine-tuned model should answer factual queries correctly. For example, it reports the RP2350 maximum clock as 150 MHz, while the base model might hallucinate a higher value.
