Overview
The NVIDIA DGX Spark pairs an Arm-based Grace CPU with a Blackwell GPU in a compact desktop form factor. The GPU handles the compute-intensive training passes while the Grace CPU manages data preprocessing and orchestration, making the system well suited for fine-tuning large language models locally without sending data to the cloud.
To get started, you’ll configure Docker, pull a pre-built PyTorch container, and install the libraries you need for fine-tuning.
Configure Docker permissions
Docker is pre-installed on the DGX Spark, so you don’t need to install it yourself. However, your user account might not have permission to run Docker commands without sudo.
Check whether Docker is accessible by opening a terminal and running:
docker images
If this prints a table (even an empty one), you’re all set and can skip ahead to the next section. If you see a permission denied error, add your user to the docker group:
sudo usermod -aG docker $USER
newgrp docker
The first command grants your user Docker access, and newgrp docker activates the new group membership in your current shell so you don’t need to log out and back in. Verify that it worked by running docker images again. You should now see the table without any errors.
Download PyTorch container
NVIDIA provides pre-built PyTorch containers that include all the necessary frameworks, libraries, and dependencies optimized for NVIDIA GPUs. These containers are regularly updated and maintained, ensuring you have access to the latest stable versions without the complexity of manual dependency management.
Pull the latest PyTorch container from NVIDIA’s container registry:
docker pull nvcr.io/nvidia/pytorch:25.11-py3
This command downloads the November 2025 release of the PyTorch container, which includes PyTorch, CUDA libraries, cuDNN, and other essential tools pre-configured for optimal performance on NVIDIA hardware. The download size is several gigabytes, so this step can take a few minutes depending on your internet connection.
Launch container instance
Now that you have the container image, you can launch an interactive session where you’ll perform all your fine-tuning work.
Run the following command to start the container:
docker run --gpus all -it --rm --ipc=host \
-v $HOME/.cache/huggingface:/root/.cache/huggingface \
-v ${PWD}:/workspace -w /workspace \
Here’s what each flag does:
  • --gpus all gives the container access to all available GPUs on your system
  • --ipc=host enables shared memory between the host and container, which is essential for multi-GPU training and data loading
  • -v $HOME/.cache/huggingface:/root/.cache/huggingface mounts your Hugging Face cache directory, preventing repeated downloads of models and datasets
  • -v ${PWD}:/workspace -w /workspace mounts your current directory into the container and sets it as the working directory, so you can access the fine-tuned model from outside the container later
After running the command, you’ll be inside the container with a root shell prompt.
Install dependencies
The base PyTorch container doesn’t include all the specialized libraries needed for efficient model fine-tuning. You need to install several additional Python packages that provide transformer models, parameter-efficient fine-tuning methods, dataset utilities, and training frameworks.
Inside the running container, install the required dependencies:
pip install transformers peft datasets trl bitsandbytes
These packages serve specific purposes:
  • transformers provides access to pre-trained language models and tokenizers from Hugging Face
  • peft (Parameter-Efficient Fine-Tuning) enables techniques like LoRA and QLoRA that reduce memory requirements
  • datasets offers a standardized interface for loading and processing training datasets
  • trl (Transformer Reinforcement Learning) includes training utilities and recipes for language models
  • bitsandbytes enables 4-bit and 8-bit quantization for memory-efficient training
The installation can take a few minutes as pip downloads and installs each package along with their dependencies.
Authenticate with Hugging Face
Many of the models you’ll fine-tune are hosted on Hugging Face’s model hub. Some models, particularly larger ones like Llama, require authentication to download. Even for public models, authentication provides better rate limits and tracking.
First, obtain an access token from your Hugging Face token settings page. Then authenticate:
hf auth login
When prompted, paste your token and press Enter. When asked about git credentials, enter n since you don’t need git integration for this workflow. This authentication persists across sessions because you mounted your Hugging Face cache directory, so you won’t need to repeat this step.
Download NVIDIA DGX Spark playbook
NVIDIA provides a collection of ready-to-use fine-tuning scripts optimized for DGX systems. These scripts implement best practices for various model sizes and fine-tuning techniques, so you can focus on your dataset and model selection rather than training boilerplate.
Clone the playbooks repository:
git clone https://github.com/mhall119/finetuning-scripts.git
cd finetuning-scripts/nvidia
The repository contains a fork of the scripts found in NVIDIA’s Playbook including the fine-tuning scripts you’ll use in the next steps. This script is preconfigured with sensible defaults but also accepts command-line arguments for customization.
In this section you:
  • Configured Docker permissions on DGX Spark
  • Pulled the NVIDIA PyTorch container and launched an interactive session
  • Installed fine-tuning libraries and authenticated with Hugging Face
  • Cloned the fine-tuning scripts repository
In the next section, you’ll learn how supervised fine-tuning works and what makes it effective for adapting pre-trained models to specific tasks.
