Give feedback
AI-assisted
Close
What should I check on the DGX Spark host before starting the containers?
Run uname -m and confirm the architecture is aarch64. Use nvidia-smi to verify GPU visibility, then run docker run --rm --gpus all ubuntu nvidia-smi to confirm GPU access from containers.
How do I get the Telegram bot token and chat ID for the runtime configuration?
Start a chat with BotFather, send /newbot, and copy the HTTP API token it returns. Send a test message to your new bot, call curl "https://api.telegram.org/bot<your-telegram-bot-token>/getUpdates", and copy message.chat.id. Set both values in .env before starting the services.
How do I know that local memory persistence is working?
Send /mem #home The boiler should be inspected every October. in Telegram, then ask /rag memory: When should the boiler be inspected?. You should see October in the response. Confirm the record directly in the personal_tracker_memory Qdrant collection with the documented payload query.
Where do I upload documents for RAG, and how can I confirm ingestion?
Create the file on the device running your Telegram client and upload it with the /knowledge caption. Copy the returned filename, wait for indexing, and ask /rag <returned-file-name> a question about the file. Check the personal_knowledge_base Qdrant payload for that filename to confirm ingestion.
How do I verify that proactive scheduling is active?
Create a job with /cron add, confirm it’s enabled with /cron list, and wait for the configured time. Check Telegram for the notification and inspect docker logs --tail 30 openclaw-cron for the [cron] dynamic job sent entry. You can use /cron run <job-id> to test the job without waiting.
Return to Laptops and Desktops
