Cross-platform portability
You can optionally move the runtime from NVIDIA DGX Spark to a CIX-based Radxa Orion O6 running Debian 12. llama.cpp provides local generation on the Armv9 CPU.
The Telegram interface, local memory and RAG, browser search, scheduled workflows, and deterministic routing remain unchanged. Only the local generation backend changes:
PlatformLocal generation backendRuntime API contract
NVIDIA DGX SparkvLLMOpenAI-compatible API
Radxa Orion O6llama.cppOpenAI-compatible API
Note
These backends match the environments used in this Learning Path and in the Run ERNIE-4.5 Mixture of Experts model on Armv9 with llama.cpp Learning Path. You can use another local backend with a compatible OpenAI chat-completions API.
Verify system requirements on Armv9 host
On Orion O6, confirm the operating system, architecture, CPU features, memory, and disk capacity:
uname -a
cat /etc/os-release
lscpu
free -h
df -h /
Confirm that the host reports aarch64 and has enough available memory and storage for the selected GGUF model and containers.
Prepare llama.cpp and the ERNIE model
To set up llama.cpp and the ERNIE model, see Set up llama.cpp on an Armv9 development board . Install the dependencies, compile llama.cpp, download the ERNIE-4.5 Thinking Q4 GGUF model, and run its basic inference test.
The following commands use these installation paths:
$HOME/llama.cpp/build/bin/llama-server
$HOME/models/ernie-4.5/ERNIE-4.5-21B-A3B-Thinking-Q4_0.gguf
Deploy a llama.cpp OpenAI-compatible server
Start the server on the host:
cd $HOME/llama.cpp
./build/bin/llama-server \
  --jinja \
  -m $HOME/models/ernie-4.5/ERNIE-4.5-21B-A3B-Thinking-Q4_0.gguf \
  -c 2048 \
  -t 12 \
  --host 127.0.0.1 \
  --port 8080
From another shell, inspect the model endpoint:
curl http://127.0.0.1:8080/v1/models
Send a short completion request:
curl -sS http://127.0.0.1:8080/v1/chat/completions \
  -H 'Content-Type: application/json' \
  -d '{
    "model": "ernie-o6",
    "messages": [{"role":"user","content":"Reply with one sentence about local AI on Arm."}],
    "max_tokens": 80,
    "temperature": 0.2
Don’t continue until this local endpoint generates a valid response.
Press Ctrl+C in the server shell after the smoke test. Create a user systemd service so that llama.cpp starts automatically and restarts after a failure:
mkdir -p $HOME/.config/systemd/user
tee $HOME/.config/systemd/user/openclaw-llama.service > /dev/null <<'EOF'
[Unit]
Description=llama.cpp server for the OpenClaw-based runtime
Wants=network-online.target
After=network-online.target
[Service]
Type=simple
ExecStart=%h/llama.cpp/build/bin/llama-server --jinja -m %h/models/ernie-4.5/ERNIE-4.5-21B-A3B-Thinking-Q4_0.gguf -c 2048 -t 12 --host 127.0.0.1 --port 8080
Restart=on-failure
RestartSec=5
[Install]
WantedBy=default.target
EOF
Enable the service and allow it to remain active when you log out:
systemctl --user daemon-reload
systemctl --user enable --now openclaw-llama.service
sudo loginctl enable-linger $USER
systemctl --user status openclaw-llama.service --no-pager
Confirm that the managed endpoint responds:
Provision Ollama and Qdrant
Install Ollama on the Orion O6 host:
curl -fsSL https://ollama.com/install.sh | sh
sudo systemctl enable --now ollama
The CPU-only compose file uses host networking, so its containers can reach Ollama through 127.0.0.1:11434. Pull the embedding model:
ollama pull nomic-embed-text
Confirm that Ollama responds and lists nomic-embed-text:
curl http://127.0.0.1:11434/api/tags
Check whether the Qdrant container already exists:
docker ps -a --filter name=openclaw-qdrant
If the container already exists, start it:
docker start openclaw-qdrant
Otherwise, create persistent storage and start Qdrant. Bind its ports to localhost:
docker volume create openclaw-qdrant-data
docker run -d \
  --name openclaw-qdrant \
  --restart unless-stopped \
  -p 127.0.0.1:6333:6333 \
  -p 127.0.0.1:6334:6334 \
  -v openclaw-qdrant-data:/qdrant/storage \
  qdrant/qdrant:latest
Confirm that the local API responds:
curl http://127.0.0.1:6333/collections
Configure the CPU-only runtime environment
Clone the same release on Orion O6:
cd $HOME
git clone https://github.com/odincodeshen/openclaw-arm-continuum.git
cd openclaw-arm-continuum
git checkout v1.2
cp .env.arm-cpu-only.example .env
Create a separate bot for this runtime with the Telegram Bot tutorial . Don’t reuse the DGX Spark bot token because two polling runtimes can compete for its updates. Have each account send a message to the new bot, then repeat the getUpdates process from the DGX Spark setup to obtain each message.chat.id value.
Generate a new Gateway token:
openssl rand -hex 32
Set the new bot and private tokens in .env:
OPENCLAW_TELEGRAM_BOT_TOKEN=<your-telegram-bot-token>
OPENCLAW_TELEGRAM_ALLOWED_CHAT_IDS=<first-telegram-chat-id>,<second-telegram-chat-id>
OPENCLAW_CRON_CHAT_IDS=<first-telegram-chat-id>,<second-telegram-chat-id>
OPENCLAW_GATEWAY_TOKEN=<generated-gateway-token>
OPENCLAW_CRON_TIMEZONE=<your-IANA-timezone>
Separate multiple chat IDs with commas. Use the same IANA timezone format as before; scheduled jobs use UTC if you omit it.
Confirm the inference settings:
OPENCLAW_VLLM_BASE_URL=http://127.0.0.1:8080/v1
OPENCLAW_VLLM_MODEL=ernie-o6
OPENCLAW_VISION_ENABLED=false
OPENCLAW_TRACKER_COLLECTION=personal_tracker_memory
OPENCLAW_KNOWLEDGE_COLLECTION=personal_knowledge_base
The VLLM variable name is retained for compatibility, but it can point to llama.cpp.
Using the same collection names keeps the configuration consistent, but it doesn’t copy Qdrant data from DGX Spark. Each host keeps its own data.
Keep the CPU-only context small and disable unused voice transcription:
OPENCLAW_MAX_TOKENS=128
OPENCLAW_RETRIEVAL_LIMIT=3
OPENCLAW_SCRAPER_LIMIT=2
OPENCLAW_WEB_CONTEXT_CHARS=1800
OPENCLAW_WHISPER_ENABLED=false
Launch the CPU-only application stack
Start the full tutorial stack:
docker compose \
  --env-file .env \
  -f compose.arm-cpu-only.yaml \
  --profile web \
  --profile gateway \
  up -d
Check the services:
docker compose --env-file .env -f compose.arm-cpu-only.yaml ps
docker logs --tail 80 openclaw-telegram
docker logs --tail 80 openclaw-memory-watcher
docker logs --tail 80 openclaw-cron
Confirm that the browser worker can resolve a public hostname:
docker exec openclaw-browser-scraper python -c "import socket; print(socket.gethostbyname('duckduckgo.com'))"
Note
If this command can’t resolve the hostname, inspect the Orion host DNS configuration with cat /etc/resolv.conf. Then update OPENCLAW_DNS_SERVER_1 and OPENCLAW_DNS_SERVER_2 in .env with DNS servers that are reachable from your network, restart the stack, and run the check again.
Validate shared workflows on CPU
Test the CPU-only deployment with a budget assistant shared by two household members.
Create a file named budget.txt on the device that you use Telegram on:
Shared household weekly budget: £120.
Upload the file with the /knowledge caption and copy the filename returned by the bot. Each allowlisted household member can then add a synthetic expense from their own chat:
/mem #budget Groceries: £45.
/mem #budget Household supplies: £20.
After both entries are saved, either member can ask:
/rag <returned-file-name> Based on the shared budget and the saved budget entries, how much remains?
Replace <returned-file-name> with the filename that was returned when you uploaded budget.txt.
The response should report that £55 remains. Both members use the same local collection, without separate per-member access controls.
The response alone doesn’t prove which inference backend generated it. Inspect the Telegram runtime log:
docker logs --tail 20 openclaw-telegram
Look for the memory write handled by memory_agent and the completed retrieval request handled by rag_agent. Then, inspect the llama.cpp service log:
journalctl --user -u openclaw-llama.service -n 30 --no-pager
Look for a successful request to /v1/chat/completions. The Telegram response and both log entries confirm that the OpenClaw-based workflow is now using llama.cpp for local generation on the Armv9 CPU.
Compare Arm deployment architectures
You’ve now built a local-first household assistant with memory, document RAG, browser search, and scheduled notifications. You ran the assistant with vLLM on NVIDIA DGX Spark, then moved it to llama.cpp on Radxa Orion O6.
The following comparison shows what stayed the same across the two Arm-based implementations and what changed with the local generation backend:
LayerNVIDIA DGX SparkRadxa Orion O6
Reference runtime servicesSame servicesSame services
User interfaceTelegramTelegram
SkillsMemory, RAG, search, weather, cronSame skills
Vector memoryQdrantQdrant
EmbeddingsOllamaOllama
Generation APIOpenAI-compatibleOpenAI-compatible
Generation enginevLLMllama.cpp
Inference computeArm CPU + NVIDIA GPUArm CPU
Each platform uses model and context settings suited to its compute while preserving the same application contract.
Review data privacy boundaries
The runtime keeps the following under your control:
  • Inference requests
  • Generated context
  • Qdrant collections
  • Uploaded files
  • Cron history
  • OpenClaw tasks
  • Gateway state
Telegram still transports messages and uploads. Weather and browser searches contact public services, while setup downloads models and containers from external registries.
For sensitive deployments, review network exposure, Telegram suitability, host access, backups, model provenance, and the contents of every enabled tool.
What you’ve accomplished
You’ve now moved the OpenClaw-based runtime from DGX Spark to a CPU-only Armv9 system by replacing the inference endpoint.
The same endpoint-driven design can support additional deployment shapes:
  • An always-on CPU-only Arm server with a compact local model
  • An Arm edge gateway connected to a trusted private-LAN inference server
  • A heterogeneous Arm AI workstation hosting larger local models
Each deployment changes the compute and trust boundary. It shouldn’t silently change where personal data is stored or which external services are contacted.
