Transition from inference to an assistant
Running a local LLM gives you private text generation, but not a complete assistant. You still need an interface for questions, saved information, document searches, and reminders.
In this Learning Path, you’ll deploy OpenClaw Arm Continuum and use it from Telegram. You’ll save a household note, query a local document, search the web, and schedule a notification. Inference, embeddings, documents, vector memory, and task state remain on hardware that you control.
Telegram is the messaging interface. The runtime can support another platform through a gateway that translates its messages and events.
OpenClaw provides the foundation for the assistant. The reference runtime connects it to Telegram, local generation through vLLM or llama.cpp, Ollama embeddings, Qdrant memory, browser search, and scheduled tasks. It routes each request to the relevant local service or tool.
Understand the data boundary
Local-first doesn’t mean that every byte stays offline. Telegram and web search use external services, while the core AI data remains under your control.
Data or operationLocationExternal interaction
LLM inferenceDGX Spark or CPU-only Arm hostModel weights are downloaded during setup
EmbeddingsLocal Ollama serviceModel weights are downloaded during setup
Vector memory and RAGLocal Qdrant serviceNone during normal retrieval
Uploaded documentsLocal runtime workspaceTelegram transports the original upload
Cron state and task historyLocal workspace and Gateway stateTelegram transports push messages
External data lookupLocal skillPublic data service selected by the skill
Browser searchLocal Playwright workerSearch engine and selected public pages
The runtime doesn’t use a public cloud LLM API. Telegram transports bot messages, and browser searches send requests to external websites.
Note
Don’t enter real personal, household, or organizational information. Instead, use synthetic or public data. If the host already contains personal runtime data, set environment variables by following the instructions in Configure and start the OpenClaw runtime on DGX Spark .
Trace the application request path
The architecture shows how Telegram requests reach local services and persistent data:
Image Alt Text:Architecture of the OpenClaw-based local-first reference runtime, including Telegram, request routing, local capabilities, persistent state, and replaceable inference enginesOpenClaw-based local-first reference runtime
The reference runtime can also start a configured workflow automatically, without requiring a new Telegram message from the user:
Cron schedule
    -> Reference runtime cron worker
    -> Local skill and local LLM
    -> Telegram push notification
Slash commands follow fixed routes. For example, /search always selects browser search, while a plain-language weather question selects the weather skill.
Note
The runtime uses a text-first architecture, fixed skill routes, and one local LLM endpoint. This Learning Path doesn’t cover multi-model routing, multi-agent handoffs, or hardware benchmarking.
Understand the shared API contract across Arm platforms
The same workflow uses an inference engine suited to each platform:
PlatformInference engine
NVIDIA DGX SparkvLLM server
Radxa Orion O6llama.cpp server
Both expose an OpenAI-compatible chat-completions API, so only the configured endpoint and model name change.
You now understand the runtime components, data boundary, and shared inference API.
Next, you’ll prepare the NVIDIA DGX Spark and configure Ollama and Qdrant.
