Arm KleidiCV is an open-source library that provides fast, optimized routines for Arm CPUs. You can use KleidiCV with any computer vision (CV) framework to boost performance for CV workloads on Arm systems.
KleidiCV includes multiple optimized implementations for each function, targeting Arm Neon, SVE2 (Scalable Vector Extension 2), and SME2 (Scalable Matrix Extension 2) instruction sets. The library automatically detects your hardware and chooses the fastest available code path, so you don’t need to adjust your code for different Arm CPUs.
You can use KleidiCV as a standalone image processing library or integrate it with OpenCV for broader computer vision support. On Apple M4 processors, which use the Armv9.2‑A architecture and support SME, you’ll see improved performance for matrix operations. In this Learning Path, you’ll build and test KleidiCV to observe how it selects the best backend for your hardware.
To follow this example you’ll need a MacBook Pro with an Apple Silicon M4 processor.
To check your operating system version, follow these steps:
sw_vers
The output is similar to:
ProductName: macOS
ProductVersion: 15.5
BuildVersion: 24F74
If CMake is not already installed on your host machine, you can install it using Homebrew:
brew install cmake
To check which Arm architecture features your Mac supports, run the following command in your terminal:
sysctl -a | grep hw.optional.arm.FEAT
Look for hw.optional.arm.FEAT_SME: 1 in the output. If you see this line, your system supports SME (Scalable Matrix Extension). If the value is 0, SME is not available on your hardware.
The output is:
hw.optional.arm.FEAT_CRC32: 1
hw.optional.arm.FEAT_FlagM: 1
hw.optional.arm.FEAT_FlagM2: 1
hw.optional.arm.FEAT_FHM: 1
hw.optional.arm.FEAT_DotProd: 1
hw.optional.arm.FEAT_SHA3: 1
hw.optional.arm.FEAT_RDM: 1
hw.optional.arm.FEAT_LSE: 1
hw.optional.arm.FEAT_SHA256: 1
hw.optional.arm.FEAT_SHA512: 1
hw.optional.arm.FEAT_SHA1: 1
hw.optional.arm.FEAT_AES: 1
hw.optional.arm.FEAT_PMULL: 1
hw.optional.arm.FEAT_SPECRES: 0
hw.optional.arm.FEAT_SPECRES2: 0
hw.optional.arm.FEAT_SB: 1
hw.optional.arm.FEAT_FRINTTS: 1
hw.optional.arm.FEAT_PACIMP: 1
hw.optional.arm.FEAT_LRCPC: 1
hw.optional.arm.FEAT_LRCPC2: 1
hw.optional.arm.FEAT_FCMA: 1
hw.optional.arm.FEAT_JSCVT: 1
hw.optional.arm.FEAT_PAuth: 1
hw.optional.arm.FEAT_PAuth2: 1
hw.optional.arm.FEAT_FPAC: 1
hw.optional.arm.FEAT_FPACCOMBINE: 1
hw.optional.arm.FEAT_DPB: 1
hw.optional.arm.FEAT_DPB2: 1
hw.optional.arm.FEAT_BF16: 1
hw.optional.arm.FEAT_EBF16: 0
hw.optional.arm.FEAT_I8MM: 1
hw.optional.arm.FEAT_WFxT: 1
hw.optional.arm.FEAT_RPRES: 1
hw.optional.arm.FEAT_CSSC: 0
hw.optional.arm.FEAT_HBC: 0
hw.optional.arm.FEAT_ECV: 1
hw.optional.arm.FEAT_AFP: 1
hw.optional.arm.FEAT_LSE2: 1
hw.optional.arm.FEAT_CSV2: 1
hw.optional.arm.FEAT_CSV3: 1
hw.optional.arm.FEAT_DIT: 1
hw.optional.arm.FEAT_FP16: 1
hw.optional.arm.FEAT_SSBS: 0
hw.optional.arm.FEAT_BTI: 1
hw.optional.arm.FEAT_SME2: 1
hw.optional.arm.FEAT_SME_F64F64: 1
hw.optional.arm.FEAT_SME_I16I64: 1
If your Mac does not have an M4 processor, you won’t see the FEAT_SME flags set to 1. In that case, SME (Scalable Matrix Extension) features are not available on your hardware, and KleidiCV will use other optimized code paths instead.
You can use an environment variable to define your workspace:
export WORKSPACE=<your-workspace-directdory>
For example,
mkdir $HOME/kleidi
export WORKSPACE=$HOME/kleidi
To set up KleidiCV and OpenCV, first download the source code from GitLab.
In your $WORKSPACE directory, clone KleidiCV using the v0.6.0 release tag:
cd $WORKSPACE
git clone -b 0.6.0 https://git.gitlab.arm.com/kleidi/kleidicv.git
Clone the OpenCV repository into $WORKSPACE using the v4.12.0 release tag:
cd $WORKSPACE
git clone https://github.com/opencv/opencv.git
cd opencv
git checkout 4.12.0
Apply the patch for OpenCV version 4.12:
patch -p1 < ../kleidicv/adapters/opencv/opencv-4.12.patch
patch -p1 < ../kleidicv/adapters/opencv/extra_benchmarks/opencv-4.12.patch
KleidiCV provides several CMake options to control which instruction sets and features are enabled during the build.
Here are the most important options for Arm systems:
You can set these options when running cmake to customize your build for your hardware and use case.
KleidiCV automatically selects the fastest available code path for your hardware. If the library detects that SVE2 (Scalable Vector Extension 2) or SME2 (Scalable Matrix Extension 2) is slower than Neon for a specific function, it defaults to Neon—unless you explicitly turn off this behavior by setting -DKLEIDICV_LIMIT_SVE2_TO_SELECTED_ALGORITHMS=OFF or -DKLEIDICV_LIMIT_SME2_TO_SELECTED_ALGORITHMS=OFF.
Use the following command to build KleidiCV natively:
cmake -S $WORKSPACE/kleidicv \
-B build-kleidicv-benchmark-SME \
-DKLEIDICV_ENABLE_SME2=ON \
-DKLEIDICV_LIMIT_SME2_TO_SELECTED_ALGORITHMS=OFF \
-DKLEIDICV_BENCHMARK=ON \
-DCMAKE_BUILD_TYPE=Release
cmake --build build-kleidicv-benchmark-SME --parallel
Once the build completes, the KleidiCV API and framework tests appear below:
ls ./build-kleidicv-benchmark-SME/test/framework/kleidicv-framework-test
ls ./build-kleidicv-benchmark-SME/test/api/kleidicv-api-test
The KleidiCV benchmark test is available as follows:
ls ./build-kleidicv-benchmark-SME/benchmark/kleidicv-benchmark
You can use the following command to build OpenCV with KleidiCV:
cmake -S $WORKSPACE/opencv \
-B build-opencv-kleidicv-sme \
-DWITH_KLEIDICV=ON \
-DKLEIDICV_SOURCE_PATH=$WORKSPACE/kleidicv \
-DBUILD_LIST=imgproc,core,ts \
-DBUILD_SHARED_LIBS=OFF \
-DBUILD_TESTS=ON \
-DBUILD_PERF_TEST=ON \
-DWITH_PNG=OFF
cmake --build build-opencv-kleidicv-sme --parallel --target opencv_perf_imgproc opencv_perf_core
Upon completion of the build process, the OpenCV test binary will be available at the following location:
ls build-opencv-kleidicv-sme/bin/opencv_perf_core
ls build-opencv-kleidicv-sme/bin/opencv_perf_imgproc
You’ve successfully set up your development environment, downloaded the KleidiCV and OpenCV source code, and built both libraries with SME2 support on your Apple Silicon Mac. At this point, you have all the tools you need to explore how KleidiCV optimizes for Arm architectures.
In the next section, you’ll run benchmarks to see SME in action and learn how KleidiCV automatically selects the best code paths for your hardware. This will help you understand the performance benefits of Arm’s advanced instruction sets for computer vision workloads.
