Explore related resources
Give feedback
AI-assisted
Close
Where do I find and run the KleidiCV API test after the build?
Run the test binary at ./build-kleidicv-benchmark-SME/test/api/kleidicv-api-test. It prints the number of tests executed and their results to confirm the build works.
What result should I expect from the API test to confirm success?
Expect output similar to a vector length report and a summary of tests run and passed. A clean pass indicates the build and public API are functioning.
How do I verify that the SME backend is being used?
KleidiCV auto-detects your CPU and selects the fastest path: Neon, SVE2, or SME2. Review the test output in the SME verification step. On supported Apple silicon, SME support is exercised during the tests.
Do I need to change my application code to target Neon, SVE2, or SME2?
No. KleidiCV automatically detects the hardware and chooses the optimal implementation, so your code doesn’t need to change.
What should I check if the tests fail to run or report errors?
Confirm the build finished without errors and run the binary from the path shown. If issues persist, confirm that you installed the required tools, then rebuild and rerun the tests.
Return to Laptops and Desktops
