Prepare an Apple silicon Mac
You’ll build a Python app that records and transcribes English speech, translates the transcript into Spanish, and plays the Spanish speech. A local Gradio page provides the recording and playback controls. Three separate models handle inference:
StageModel and runtimeProcessorInput and output
TranscriptionEnglish Zipformer with Sherpa-ONNXCPURecorded audio to English text
TranslationGemma 4 E2B with LiteRT-LMApple GPUEnglish text to Spanish text
Speech synthesisSupertonic 3 with Sherpa-ONNXCPUSpanish text to Spanish audio
The Gemma model receives the transcript, rather than the recording itself. Translation text will appear as Gemma generates it, followed by speech synthesis starting after the translation finishes. All three models run locally after you download them, so this pipeline will work fully offline after it’s built.
Before starting, check that your terminal is running natively on Apple silicon and that Python 3.10 through 3.13 is available:
uname -m
python3 --version
The expected output from uname -m is:
        arm64
macOS uses the name arm64 for the 64-bit Arm architecture. If uname -m reports x86_64, you’re either using an Intel-based Mac or running the terminal through Rosetta.
Use Python 3.10 through 3.13 for the pinned packages in this Learning Path. If python3 reports another version, follow the Python installation instructions for macOS to install a version in this range. For example, after installing Python 3.13, check python3.13 --version and use python3.13 -m venv .venv instead of python3 -m venv .venv.
Create the Python environment
Create a project directory and a virtual environment:
mkdir -p ~/voice-translator/models
cd ~/voice-translator
source .venv/bin/activate
python -m pip install --upgrade pip
Note
Keep this virtual environment active while you complete the Learning Path. Make sure to run the scripts from ~/voice-translator because their model paths are relative to that directory.
Create a requirements.txt file in ~/voice-translator with the following contents:
gradio==6.22.0
litert-lm-api==0.17.1
numpy==2.2.6
sherpa-onnx==1.13.3
sherpa-onnx-bin==1.13.3
sounddevice==0.5.6
Install all the packages:
python -m pip install -r requirements.txt
Verify that the native packages load and that Python is running as arm64:
python -c "import platform, litert_lm, sherpa_onnx, sounddevice; print(platform.machine())"
The expected output is:
        arm64
The prebuilt LiteRT-LM and Sherpa-ONNX packages mean that you don’t need to compile either runtime from source.
Download the speech recognition model
Download and extract the quantized English streaming Zipformer model:
curl -L -o models/sherpa-asr.tar.bz2 https://github.com/k2-fsa/sherpa-onnx/releases/download/asr-models/sherpa-onnx-streaming-zipformer-en-2023-06-26.tar.bz2
tar -xjf models/sherpa-asr.tar.bz2 -C models
rm models/sherpa-asr.tar.bz2
Download Gemma 4 E2B
Download the instruction-tuned Gemma 4 E2B model packaged for LiteRT-LM:
curl -L -o models/gemma-4-E2B-it.litertlm https://huggingface.co/litert-community/gemma-4-E2B-it-litert-lm/resolve/main/gemma-4-E2B-it.litertlm
The file is about 2.6 GB, so the download can take several minutes.
Keep the filename gemma-4-E2B-it.litertlm. The translation script uses this path when it opens the model.
Download the speech synthesis model
Download and extract the quantized Supertonic 3 model:
curl -L -o models/supertonic.tar.bz2 https://github.com/k2-fsa/sherpa-onnx/releases/download/tts-models/sherpa-onnx-supertonic-3-tts-int8-2026-05-11.tar.bz2
tar -xjf models/supertonic.tar.bz2 -C models
rm models/supertonic.tar.bz2
You’ll use Supertonic 3 to turn the Spanish translation into speech. The model also supports other languages. For information about supported languages, see the Supertonic 3 language documentation .
Verify the model files
Check that one required file from each model is present:
ls models/gemma-4-E2B-it.litertlm \
   models/sherpa-onnx-streaming-zipformer-en-2023-06-26/encoder-epoch-99-avg-1-chunk-16-left-128.int8.onnx \
   models/sherpa-onnx-supertonic-3-tts-int8-2026-05-11/duration_predictor.int8.onnx
Confirm that all three filenames are listed. If ls reports a missing file, check that model’s download and extraction before continuing.
You’ve set up the voice translation project. The Python imports and file checks confirm that the dependencies load and the expected model paths exist.
Next, you’ll transcribe microphone audio with Sherpa-ONNX.
